Wait for BF or Cyber Monday, there will be discounts.
That's what I paid.. kind of the going price. Try to get free shipping
Was it worth it?
Was it worth it?
Yes from 2000-5000rpms unless you're towing 7400 lbs for 2-3 hours.
Have a 5.3L 2015
Ran with a Borla S-Type (removed flapper and resonator) for 2 weeks now and just cannot get over how bad the V4 sounds. V8 is mint which is a drag.
Ordered the GM-Borla kit that has the valve to control drone/helicopter noise.
QUESTION: has anyone installed this kit, then swapped out the muffler for an S-type?
Have a 5.3L 2015
You have the full catback Borla S-Type? Or just muffler? I have the full set w/ Air Raid MIT Tube and I get zero drone in V4.
I got mine from Auto anything for a little less than the Summit price...I called and talked with an operator and was able to do better than the published price.
Do you do anything to the valve to get rid of the helicopter noise? I see it is spring loaded, but cant turn or pull it out anymore?
Any Black Friday deals?? The only one I see is 4wheel parts no sales tax and free shipping $999.99 out the door
  • 5 years later...
Guys, I finally pulled the trigger and ordered the Borla S-Type exhaust for my 2014 Z71 Silverado.  I took it to a local shop as I didn't want to do this in my driveway.  However, when it came time to mount the left exhaust hangar that Borla provides, I did not have a hole in my frame like the video shows.  We ended up drilling a hole but the exhaust sticks out too far.  Any suggestions?  Btw, it sounds sick!!
Edited by Hdwrguy
Sounds like you got duals out the back? Make sure all of the connections are fully seated. If still too far out then just cut the pipe. Not sure why it would be sticking out too far as the last pipe section is supposed to still be under the bed and what sticks out are the exhaust tips...unless it's for a longer bed.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
