Adams Trim Coating
I have used it on all the exterior trim and also did my engine cover today. Here are some photos. Nice product time will tell how it lasts
Before
After
Ryan B.
Hi Ryan...not really seeing a big difference between the before and after pics....They both look great. That being said, I say you run it all through the winter without any cleaning. Once all the snow and salt in gone, take some pics....Then just wipe it off with some detail spray or equivalent type of product and take pics....then a thorough cleaning with pics...Just a thought....good luck.
That's my plan
It doesn't look like it does much but I will say my truck got rained on and normally if I just wipe the bed rails after a rain it leave it dull and I use vrt or equivalent to bring the shine back. After the first rain I just hit with a microfiber and a bit of detail spray and the shine was still there. It is a subtle product but IMO worth it
Also the first photo Illustrates the shine from the in and out spray. I washed and costed a few wks ago
I like the Adam's products, they just seem more expensive than they should be. I have a ton of their stuff.
APC is $30 a gal, plus shipping. Go to Dollar Tree and get big 32oz bottles of APC there for $1. I cleaned the Adams APC first and was amazed how much browning came off when I used the LA totally Famous afterwards. Cheaper and cleans better IMO.
Curious for exterior trim results in a month or so being exposed vs engine cover.
This time of year the engine bay gets pretty dirty with salt / snowy roads
Ryan B.
  • 1 month later...
Few photos from yesterday
Untouched no wipe down
Ryan B.
Another test on my wife's van
Before window cowl
After, still not great but much improved need a few more coats
Looks like it is holding up nicely, think I am going to add to my order in a few weeks.
Thanks for the update.
Untouched no wipe downbaf9231675da30155afa19133b1ae586.jpg36aff8470e195d5639cf3c2543195522.jpg
Ryan B.
Looks good Ryan, did you wipe that down first. If not that is really good stuff there.
No wipe down photo taken As it sat
Another update. Just hit it with some rinseless wash
Before, salty
After
Ryan B.
It looks good to me. I used to use what I think is called Adams Super VRT on my Avalanche cladding, problem was is was annoying reapplying it every month or so. Ended up getting Refinish Restorer. Hands down the best trim product on the market. Reapplied max two times per year.
By the way I really like the cardboard idea under the tire to apply tire shine, I like it.
Yea any tire stuff that gets on the floor makes it super slippery. Not good when I am working out
Ryan B.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 1,123 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
