Rust Prevention
What are some of the best methods to prevent rust from appearing on the frame and undercarriage? Is there anything you guys spray on the frame and pretty much entire undercarriage that you found to work? I know I can POR15 paint the entire frame but why do that over a fairly new frame thats not rusty yet, just trying to prevent rust from forming in the future.
Whatever you do do NOT apply fluid film. It isn't compatible with the GM wax dip and will actually eat it away and cause it to rust faster. I just spray krylon crap on my rust spots whenever i have it up on a lift at work. Not sure it does much but at least is doesnt look rusty.. :driving:
I had my truck up on a lift, and went over the frame and any spots that could capture crap with spray rubberized undercoating.
I don't live where it snows, but I do work on a steel hull boat that sits in saltwater 24/7, 365....best thing to prevent or limit rust, coat any bare metal and wash it. Dawn and fresh water will do wonders. Letting salt sit on the best of coatings will still rust in my experience.
wow who knew,
I use Carwell, get it sprayed in the fall, touch up seems throughout the year with a squeeze bottle,
http://www.carwell.com/
This is my 05 that I traded 2 years ago next week with 110k, zero rust anywhere truck was awesome and sometimes I wish I still had it, not so much with the 16 but definitely when I had the 14
A MUST DO IMO, I removed the lower rubber seals, the one along the bottom edge of the door, they trap moisture, dirt, debris, and accelerate the corrosion process, no notice in outside sound at all
IMG_20141006_142048408_HDR_zpsffe32d57.j
Does anyone sell the original factory wax type coating to just touch up where it wears off? Would something like corrosion x or boeshield work with the factory coating?
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
