2014 - Silverado/Sierra Owners - Puddle Lamps?
pgamboa
I've got 2 members here who have tried my custom harness for their DL3 Mirror Upgrade. They have reported their puddle lamps being dim.
Does anyone here have a 2014 with puddle lamps working? I'd love to see your X500 Connector Pinout to ensure the circuits are pinned the same. The Upfitter manual leaves a lot to be desired for 2014 with only 200 pages. 2015 has about 900 pages, while 2016 has 1600 pages. :)
Thanks in advance!
I read a post where a guy was asking if he could make his lamps brighter, so I wonder if there is a difference. Do you have any pics to compare the brightness by chance? If my dad could operate a smart phone I'd have him go out in the garage and take a pic of the ones on his LTZ for comparison. Lol.
No pics. Just reports that both sides are really dim to where you can't see it unless you're right under neath it. In addition, they stay on long after the other courtesy lights shut off.
From what I gather, the puddle lights only light fully when the unlock button is hit on the key fob.
Mine correspond with the light outside. I believe there is an auto sensor.
if it is a bright sunny day they are very very dim, if dark night, they are very bright, make sure they are trying them at night.
I assume the wires on your custom harness are in the same pinned locations on the DL3 harness?
Yes. Puddle Lamps and Turn Signals are pinned in the same location on DL8 and DL3 harnesses.
Also - The pinout schematics for all the pins are identical between 2015-2016 Upfitter manuals on the X500, X505, X510 connectors. The 2014 Upfitter doesn't disclose these electrical details
Why GM.. Why?
If you have DL3 Mirrors, optioned harnesses are pinned for Puddle Lamps and Auto Dim on Pins 1 & 2 on the X510 Connector.
These same slots are also used for Courtesy Lamps and Park Lamps.
They then get routed accordingly to the X500 Connector.
I guess that's why Towing Mirrors don't have Puddle Lamps and Auto Dim.
***sigh***
My puddle lamps are really bright and I used your harness! They only turn on when I hit the unlock on the fob though. If I remote start they are not on until I unlock on the key fob.
It's like that from the factory. They should be tied into the dome circuit so they come on whenever the door is opened IMO.
I guess they call them Puddle Lamps so that at night, they come on when you unlock from the fob to check that you don't step in a puddle of water before entering. LOL. They turn off once you open the door. Gonna see how bright they during the daytime by covering the ambient light sensor on the dash. Also, both members with dim puddles are 2014 trucks. The Upfitter doesn't show the pinout details for this year.
Any candidates out there? Trying to learn how I can help 2014 owners out there.
I never even noticed that I had puddle lights till i read this but now that I see them I WANT some logo type bulbs in there to project like GMC onto the pavement.....can i just replace the factory bulbs with some projector bulbs or something?
Hmmm, I've never thought about changing the bulbs out. I guess anything is possible... but have never taken one apart.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
