6.2 with afe intake = 36hp!
truckguy82
I thought you were the only one that knew how every factory part flows.
nope, I only know how the intake flows
Next time you accuse a business of deception on a public forum, especially a small business, and especially where said business gets a good portion of their customers from, be sure to back it up that claim with real evidence. You're really just being a huge **** without it.
  • Replies 192
Deception? Lol. Everybody is entitled to there opinion, even if it's different than yours. Get over it.
It is a forum, and that is what they are all about.
I don't even need Dilbert anymore.
Sent from my SM-G930V using Tapatalk
No you are not entitled to your opinion as this is not a subjective discussion, we are discussing factual data and whether it is true or false. You have been trying to prove your point with data this entire time.
Whaaaaat??? LOL...Settle down there.
Cam is the same apparently. Intake, exhaust, tune are the only differences between LT1 and L86.
Right. But it's not going to suck in more air than it's capably of using just because the air is there. Obviously a 1" intake tube wouldn't flow nearly enough air. Conversely, if "more air" was always the answer, all manufacturers would have a giant 3 foot diameter orifice at the front of all of their intakes, with a screen on the front to keep out birds. And those BS K+N demos claiming "3x more air flow!" would have really yeilded their advertised +30 hp on every single car ever made instead of jack squat. Typically, CAI's without a tune make minimal hp gains. This has been proven time and time again with various dyno tests over the years. Throw a tune on and they typically add a handful of hp. Apparently one out of this bunch was able to add 25 hp without a tune. That is certainly not typical. I missed the point about the vacuum mentioned earlier so I'll have to go see if a logical explanation was included.
That's why people were talking about the map readings before and after installing an intake. Before the intake, readings were, IIRC 93-94kpa. 100kpa would be perfect and a good setup will pull around 98-99kpa. The fact that it is 93-94kpa shows that there is a restriction as the intake manifold is not able to reach atmospheric pressure. By installing a better intake, they noted it would jump up to 98-99kpa.
That's the short version of a long explanation proving that there is a restriction, stock. And that the engine would benefit from a better setup. Initially people thought the low map / kpa readings were due to the intake manifold but it was proven it's much more from the intake itself.
I just installed the afe momentum on my 2017 5.3 this afternoon. Was talking with afe before ordering and they said to see if it fits and if it didn't they would take back and pay for shipping. No fitment issues during install.
Better get some wheelie bars and a chute.
Sounds great....stock exhaust?
Borla xr1 racing muffler part#40722 flapper clampedopen and resonator delete.. all 3 cats still in place.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
    • EV's have their nuances too. Best to operate the current type of lithium batteries between 20-80% charge. No real need to charge until you hit around 20%. Occasionally charge to 100% when needed. Longer term storage, battery should be 50-60%. At least those are the guidelines for our iX. We've been exceptionally good to the battery in that car...easy to do when you can charge at home like we can.   EV's lack so many of the rituals and so much of the visceral feeling ICE vehicles provide, which is why I think they're hard to accept for a lot of gearheads. They're fun in different ways, though.
    • We have got a lot of rain lately, we needed it. Storms/lightning took out a floor fan. Dirt roads badly rutted from run off.   Power here is sketchy, whole house surge protector in the service panel and all electronics plugged into surge protectors. My biggest concern is my stereo, I've been an audio nut for years. $25 k in equipment. Stereo is on it's own special surge protector.
    • Happy Birthday!  I also turned 72 this year.  In some groups I consider myself to be a young senior and in others I realize I have serious years behind me!  In June I spent a week in the hospital due to a blood clot following knee replacement surgery.  The hospital Doctor assigned to my care specialized in Geriatric medicine!  He is a great Doctor but the fact I required this type of specialized care  made me feel old!  Aging comes with new challenges but I sure appreciate getting older!  It most definitely beats the alternative!!
