2500HD power steering fluid
Are you guys using power steering fluid or ATF ? All the videos I have watched guys are using ATF but the amsoil website recommends power steering fluid
Wanna do a good flush.
2011 Silverado 2500hd gas
Thanks
Matt
Hi Matt, keep in mind you are flushing your reserve, cooler and your BRAKES ( Hydroboost) when you do this.. make sure you have enough.. I use PS fluid, its clear and seems better with the hydro boost in cooler weather.
Definitely use PS fluid. I found some synthetic PS fluid, but it seems to be discontinued now (at least the brand I bought), most likely because most people just buy the regular stuff.
I would only use ATF if it was an emergency situation (need to fill it up, but only atf is available).
I'm happy to hear you are going to do a flush. It's very important in promoting longevity.
Mattymax, I would use PSF. since it is part of your bakes. I can get a quote out to you if you PM me your ship to address. If you wanted to get the 4qts like posted above that one individual accomplished his with that would be 8 bottles of AMSOIL.
