Tuner/Programmer Question
I've always wanted a Blackbear tune but I'm not sure it would fit with what I do. I like to swap wheels and tires of different sizes, winter and summer, etc. I'm also a tinkerer and like to play around with the settings lol.
Sent from my E6810 using Tapatalk
  • Replies 68
Absolutely love it! Truck feels alert. And no I didn't get a custom tune for it. Didn't feel the need to. But I still mess with the tunes here and there.
So are you tune to 87 and firm shift or stock modify?
I modified the stock tune first, to change tire size, differential gear, speed limit off. Then I ran the 87 tune for a while. Then I switched to the Diablo tune.
I'm still tinkering here and there.
Sent from my XT1650 using Tapatalk
Right on yea I think I might get lew at diablew do a program for me. I like the 87 tune tho. Is the diablo tune night and day from the 87? I ask cause my tank is still full of 87 fuel lol
I couldn't tell you and be sure. I've been on the diablo tune for a while now. I'm sure if I switched back I'd notice something. But I run regular 87 gas on the diablo tune without any knocking or timing issues.
Thanks man all in all it's a good programmer. Next full up I'll do 91 and try the diablo setting
Just tuned my 15 Silverado with Diablew custom tune. Worth every penny! Customer service is awesome.
Thanks LEW!
I am curious if a hypertech max energy 2.0 part 2000 will work on a 2017 6.2 8spd. I had one borrowed long term for my 2016 and it worked very well, mainly only used it to to set the AFM to only come on above 50 mph. It belonged to a friend who did the custom tune route. It can apparently only be married to a maximum of 3 vehicles and he is hesitant to let me hook it up to try it on this new 17 truck, says it would make it unusable on any other vehicles from there forward? I don't know?
I would like to know if anyone is actually using one on a 17 6.2 8spd before I invest my hard earned cash?
  • 2 months later...
It's easy, trust me. There's even a yes and no program for the first timers. So yeah, you can change the tire size.
Amf is for V4 to V8 mode. On/off.
And TM is Torque management. Which basically turns off the transmissions 'conscience'.
A conscience ?
Manny the tranny said . " I was going to shift into turd but I was feeling bad about the chirp from first to second so I din't , meng ."
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
