GM making the app creation Process easier
Be nice if they would concentrate on fixing AFM, the Chevy shake and other bugs first.
What is wrong with the AFM, this is a whole new system on the LTx series engines and so far there hasn't been any issues like the previous generation trucks had.
On my 15 Sierra it is far from seamless. There is a shudder in the pedal an it want to activate at really low engine Temps as well as slow speeds. My 08 you never knew it had activated unless you saw V4 on the display.
My 2016 AFM is on at 2mph-10mph and 85mph depending on throttle level? If anything I would like to have it not really come on unless 30+ It comes on and off 2X as much as the previous generation in my opinion.
How can there be a shudder in the peddle when it isnt even physically connected to the engine?
If your tailgate falls off while driving down the highway, it's AFM's fault. Any and all problems that arise on a truck are due to AFM.
Need new brake pads? AFM.
Door dings? AFM.
Rust issues on the frame? Blame AFM.
AC stopped blowing cold air? Gotta be that damn AFM.
You sure that your shudder is AFM?
It might be your Torque converter, several people, including myself have had that problem, and you can feel it in your pedal...
Connected or not I can still feel a shudder through the pedal. It could be radiating from the floor board, I don't know.
I have heard of others having issues with the torque converter. I would stand to reason since the it could effect the lock up of the converter.
Door dings? AFM.
I have embraced AFM for 9+ years. I purchased my 08 Silverado 5.3 in December of 07, drove it for 9 years, and never once knew it was activated accept for the V4 indicator on the dash. It never kicked in till the truck was up to operating temp, and it only took a slight amount of pressure to deactivate.
My 15 Sierra 5.3 as I said before is far from seamless. It will activate at coolant Temps below 170. Takes more pedal pressure to deactivate, and it shudders and vibrates when active. So take that for what it's worth.
They had to activate AFM a lot sooner/more often to satisfy the EPA (fuel economy and emissions purposes).
Personally I turned it off. Unless you're a flat-lander you can hardly notice the fuel economy difference.
I agree. On my 17 it is much more noticeable than my 08. Part of the reason i ordered a range device for this truck is because it feels much more intrusive to my driving habit than on my 08. Will use it until outside of the warranty and then tune.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
