Sounds like the RCDLR is bad. IE the Passenger Door Switch.
You can find them pretty cheap on ebay just make sure if you have TPMS you get the correct PDM RCDLR
PDM US RFA = Non TPMS
PDM US RFA TPM = TPMS
Will this post is an education in itself, thank you for posting. I will have to research some of the terms you quoted but thats ok.
My one fob has been inop for many years. Elderly family member tried to replace battery and the case is in pretty poor shape, so $25.00 and two replacements has that fixed.
I will look into switch today or tomorrow, thanks again
Didn't even know the 03 Silverado had TPMS. Thought it only started in 05 and became law in 08. Also thought the RCDLR was part of the BCM in 03, I'm confused.
Edited by Coby7
You can add TPMS to the older trucks with the addition of the Correct PDM and programming. I have even removed TPMS from both the new and old body style trucks but for legal reasons I would never tell anyone how since its a safety and federally mandated after 07. To many people that want to sue for anything now days.
I only glanced at the thread and did not really look at what year he had. After posting I saw something in the tail end of one of the post that might be his fob being bad. I hope the new ones he ordered work.
As for keyless entry
03 up is not in the BCM its all in the PDM.
I guess I should add that when you have power door locks with key less that it does have its own calibration in the bcm. I flash BCMs off the car for plug and play and thats one of the required answered questions in sps before you can program.
If I enter the acronym PDM in the GM server search line for 2003 Silverado the only response I get is Pump driver module for a diesel truck. I'm trying to educate myself here so hang in there. Where physically is this PDM you're talking about located?
Its in the Passenger door lock module.
Here is all data from a 2003 silv.
https://postimg.org/image/v4re42o87/
Edited by SpartanAutoworx
Here is the sticker on the back of the switch i was talking about..
https://postimg.org/image/gvr7rxe6p/
New fobs should be here Monday at the latest, amazon says Sunday via USPS......doubt that.
So the pic is the PDM or RCDLR or whatever it is called in the passenger door? And, needs to be programmed not plug and play if I understand correct?
I sure am hoping new fobs cure the issue, lowest cost fix so far plus mine nearly 15 years old anyway and one has nor worked for years.
thanks for posting
The PDM Is the RCDLR.
As for programming GM SPS does have programming for the PDM what functionality it actually gIves I have no idea. A new one may need to be programmed but I've never had a new one in my hand. I have programed used PDM's on the bench to the correct Vin the truck it was going to be replaced in but noticed no difference in my testing from donor truck to flashed vin in the PDM.
Coby7 & SPartanAUtoworx:
We are back in business. New fobs programmed smooth and are functioning. The retailer via Amazon sent his business card and recommended I go to their www site for programming instructions. I had Coby's instructions but thought I better check their site. Only difference is they mentioned I might have to hold the Unlock and Lock buttons for as long as 30 minutes. Not even close, less 30 seconds. Both are programmed.
Now off to mend the instrument cluster once material arrives.
Thanks for all the posts and advice, I have learned allot from both of you and your assistance has been a HUGE help.
SpartanAUtoworx, Appears you may have some used parts and I see you are showing ST Louis area. That being the case you are a stone throw away from me and I will retain your posts if that is correct.
v/r
Butch
Your welcome! I believe SpartanAUtoworx also repairs clusters if you get into trouble....
Edited by Coby7
Yes, I seen he has a keen interest in many truck areas. I will keep him in mind since he is not too far from me.
Your little video really pulled all together. A faulty fob will trigger some test equipment, but at the end of the day its a dud. Hence, the test light at the retailer reading ok when it was not :-)
Now to resurrect my other thread on the cluster once I remove it. Many, many moons ago I use to do some of that work on radios, but I need to refresh the technique.
Thanks again
Yes, surface mount is a technique alright compared to through hole.
  • 4 years later...
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 475 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
