In California it's 50 for the plates the first time then 40 a year tacked onto our 450$ yearly registration
Sent from my Nexus 6P using Tapatalk
$450 registration - holey cow.........
very cool plate!.. is that an albino bear?
"The Kermode bear (Ursus americanus kermodei), also known as the "spirit bear" (particularly in British Columbia), is a rare subspecies of the American black ..." Revenue from the purchase of these plates also goes to our parks and wildlife! I am 100% with you on supporting the outdoors!
Some people pay more it goes up or down depending on the age of your vehicle and the type also.
It's crap...I believe it's something like 56$ yearly just to register as a car as inactive
I'm seeing those plates around here more often lately and they definitely make a vehicle stand out however I go back to when they were standard issues so they look out of place to me on vehicles not from that era.
In any caae thats a sharp looking truck you have there!
Sent from my SAMSUNG-SM-N920A using Tapatalk
I have New England Patriots Super Bowl plates on my truck, unfortunately it only represents 3...not sure if Ma has a current version or if they are waiting for after next season so they can have all 6, 3 on the left and 3 of the right to balance it.
Those would sure look good on a classic car or truck......... Or if you tow classics.......
If you like it go for it - but the general public could not care less about all these special plates - I get a kick out of deciphering them - and we certainly have had a few - but it's not for anything more than getting a plate you can remember.........
Washington state doesn't even emboss raise the letters anymore - so they look cheap too.........
Krusty, where in Washington are you?
I tried ordering personalized ones , but it took 8weeks to tell me no.
I might just get random ones in the black and yellow. I have a summit white with black trim.
Sent from my SM-G935T using Tapatalk
I have a black plate on my truck that I love!
The yellow lettering is pretty cool
IMG 0001
IMG 0003
Yeah it's more for pickup trucks because we get classified as "Commercial Vehicles" in CA. When I sold my Sierra and bought a Tahoe from my mom for a couple years, I was shocked that her yearly registration was so much lower even though the cars were the same year and hers had a $12k higher MSRP originally.
Thanks bro! I get compliments when I park at places, I appreciate it too. Helps reassure I made a good choice pulse it represents what helped me pay for the truck! #OilAndGas #Industry
Very nice plate! I recently purchased BC parks plates! I like unique licence plates and I don't think it matters if the colors conflict with a vehicles' color scheme!
Nice. I didn't even know these existed in BC!
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
