Sorry but did you guys remove the level kit and see if it continues to give you issues?
Also, trading it in after 2 months of ownership is crazy, you're going to get hit with such depreciation.
I tried raising tire pressure to 40 and made no difference.
Yea i called my salesman and the dealership offered me 40k for trade and the truck stickers for 58,555. So thats not happening.
No i haven't tried removing the leveling kit, mostly because wyomingcolt said he tried that and it didn't change anything, and i don't want to drop another 300+ in labor to have it removed if thats already been tried.
i would stop thinking its anything u did or modded. thousands of trucks are leveled and lifted daily....all with bigger tire set ups. Under warranty/aftermarket issues the part or mod needs to be the cause of the issue. with all the trouble shooting i dont see the level and tires being the issue. for the record i have a 2015 leveled and 33s...no issues.
Also to the tool that decided to troll the post and then bitch out....opinions are welcomed, assholes are not.
Ok, so what I've done so far to no avail is:
-Put stock tires back on
-Replaced left front hub
-Had machine shop machine my Diff spacers down
-Moved brake lines for more slack
-Checked and rechecked and rechecked abs wires
-Installed new bushing spacers for more Camber(this actually helped the ride and drive but not abs/stabilitrak issue) truck drives different but improved different
-Reset Ride control like 10 times
-Reset Steering angle yaw sensor like 10 times
None of this has fixed my ABS/Stabilitrak going off around corners. I now have one last shop in Colorado that specializes in lifting trucks as their business. All I have left to hope for is ride height sensors being my problem.
Put it back to stock, it's that simple. Why in the world people change the suspension/steering geometry and tire size and don't expect problems is mind boggling.
Computers do everything but steer for you, any deviation from stock and you're playing with fire.
Edited by isellpower
typical sheep type statement
Better not put mudflaps, steps, vent shades, or tonneaus on. Might cause issues with your flux capacitor and void your warranty. SMH
Edited by wildchevys
  • Like 6
The local shop told me that too much axle end play can cause the ABS light to pop on corners...the air gap between the sensor and tone ring opens up during a turn. Something to consider.
Isellpower;
I understand what u are saying but these gm trucks look like a Canyon without SOME kind of lift/leveling. Leveling a truck a couple inches should NOT cause a Stabilitrak issue.
Sdeeter19555:
Thank u for your post. I have never heard of that. But how do u fix that!?
I really have no idea, on a c-clip axle that would mean the clip has too much play, which usually happens with lots of miles?
It's been almost 20 years since I was elbow deep in a rear differential, but want to remember you can shim either under the clip or under the side gear to take up some of that play? Thinking open carrier: the cross pin limits inward movement, the clip outward movement? You would shim under the side gear/clip until you could just get the cross pin installed. This was the method to tighten up a Lock-Right locker...
2015 GMC 2500HD 4x4 | Cognito 4-6 in Lift | 35in Tires
I have the same StabiliTrack/ABS problem with my 2015 GMC 2500HD....
Dealership is unable to diagnose. Just started recently........
Edited by 2105GMC2500HD
My 16 with a 2.5" front level started doing this as well but only make tight right turns. Left is fine
Zcusker,
Answer to my issue was to take back to actual stock first. No more issues. Put on a suspension Maxx leveling kit tonight with a rough country rear block and rear shock extenders. All my issues were GONE at stock. Will post as I drive it tomorrow
Mine is on also. Just lifted my truck with a BDS 6" Cognito UCA's and FOX Coilovers. It hasn't been aligned yet so I am hoping that fixes it. But from what y'all is going through probably not.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
