Simple. Pull a oil sample and have it tested to confirm fuel dilution. Don't rely on conjectures, "sniff tests", and other shade tree stuff. If you are going to try and get the dealer to do something, having a recent used oil sample test result in hand goes a long, long way to supporting your argument. You can get UOA kits and testing done for $25 or less from dozens of testing labs and they can have you the results in a week of sending in the sample.
Edited by Cowpie
This is a normal occurrence with direct injection engines
Diesels add diesel fuel on an exhaust stroke fueling the DPF sytem to heat up to 1400 or higher....different system! Engine cycles egr gas and soot into combustion cylinder to treat NOX gas, this accumulates in oil changing oil quality, diesels are not gas engines.
Gas engines don't do this, just a simple egr gas only.
I was just saying a similar problem I know of. I know they are different motors.
Definitely different, but like you said, the cause of the problem is likely the same. Injectors leaking with the engine off.
Sent from my SM-G920V using Tapatalk
Clearly, diesel or gas, fuel dilution is a product of improperly set injector timing, leaking injectors, poor piston rings, etc. Excessive idling can cause fuel dilution and excessive short trip, incomplete engine oil warmup will amplify fuel dilution issues by not allowing oil to come up to full operating temperature which is such that fuel that has gotten into the oil will vaporize off and go thru the PCV line back to the intake.
Engine up at operating temp does not mean that oil has reached operating temperature. There is a lag, with oil temp coming up slower than coolant temp. This is why operating the engine at normal temps for longer than a short trip is critical to get the oil up to temp also.
Edited by Cowpie
"This is a normal occurrence with direct injection engines"
Yes and no. Based on the used oil analyses I have seen, Direct Injection engines do tend to exhibit more fuel dilution than their non-DI counterparts, but typically does not consist of more than 1% of the oil volume unless there is a mechanical defect (such as a leaking injector as some have suggested).
Seeing the oil quantity creep up as much as the original poster's does is not normal. Recommend an oil analysis to see what the % of fuel dilution.
  • 2 years later...
  • 6 months later...
I also own a 2016 Silverado Z71 that had had an issue with increased oil level, fuel smell in the oil, decreased fuel mileage, and a heavy raw fuel smell on start up. As others have noted, if it doesn't throw a code, the problem doesn't exist. (IMO: This is the difference between a mechanic and a technician.) I have asked my dealer to pull a fuel dilution oil sample, but they still won't and tell me I need to get it done myself. They've stalled this issue to the point that the bumper to bumper warranty is now expired and I've gotten GM Customer Service involved.
So far, the result is the same. "We can't find anything because it's not giving us a code!"
My truck now has 34K on it and this issue has been present for about 20K and I've even been accused of adding extra oil.
I know it's a leaking injector or two. Rough, noisy start ups, rough idle cold or warm, and a drop of about 6 to 10 mpg over all.
If others suffer from this same problem, I'd like to hear from you, problem solved or not. It's past being old and into the realm of total stupidity. This should be documented to GM and addressed.
You've been running your truck with fuel in the oil for 20K miles?  That's a huge mistake, as fuel kills the oils ability to lubricate...
IMHO, you need to pony up for the oil test ASAP, and get the problem fixed, as your engine is getting more and more damaged from this every day...
The issue isn't a consistent problem and I'm not dumb enough to drive it 20K with diluted oil. It's spent quite a bit of time at the dealership, (being largely ignored), and I've finally told them I'll drive the S.O.B. until it blows up. Hopefully, Customer Service is getting Technical involved and we'll have a solution. If not, I'll request they buy it back.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
