Debadging Question
  • Replies 36
3M eraser wheel that attaches to your drill. This thing takes all the time out of it. Heat up badges, fishing line to remove, then use the 3M eraser wheel. I have a black truck... Left no scratches at all. You'll need a little bit of goo-gone to gently remove left behind adhesive, spray detail the area, and I put some wax after everything was off.
People, we know the best method to debadge by now, read previous posts... Turn the page
Really a simple question: What do you guys use to get the adhesive glue off the truck when you're debadging it? I have done this before and just used fishing line to get most of it off, then Goo Gone and it worked like a charm. For some reason I'm having a pain in the ass getting the "Silverado" off both my doors tonight. I got 95% of the glue off but seem to be struggling with the little bit thats remaining. Any tips? I don't have a polished/buffer or I'd probably just use that.
Thanks guys.
WD40
Anyone take off the door emblems from a midnight edition that would want to sell one? Send me a PM
  • 4 weeks later...
Can anyone explain a little more on how to use the fishing line. Do u use a braid on regular line? Just slide it behind the emblems or use a sawing motion? Do u tie handles to it to help?
Sent from my SM-G920V using Tapatalk
I just used regular line, and sawing motion while pulling downwards slightly. Make sure not to pull towards you, as you don't want the badge to angle too much and dig into the paint.
You can make loops on the end for your hands if you want, but I just wrapped a couple loops around my fingers.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
