1500 with e-rated tires - PSI?
20Silverado11
Hello,
It's new tire time for my 1500 and, since we're planning on pulling a horse trailer all over this spring/summer, I opted for more robust tires. Originally, the truck came with Goodyear p275/55r20's, which I hated and immediately swapped for p265/65r18 Michelin LTX tires (got the stock 18" Chevy rims on eBay). Per the door "Tire and Loading Information" sticker on the truck, I was supposed to run 30 PSI, but I put 33 PSI in for driving around empty and 35 PSI in for towing. But, they do feel a bit mushy and people have told me I should get e-rated tires for pulling a horse trailer around. The new tires I've just ordered at Costco are the Michelin Defender LTX's that are e-rated and are 275/65r18. I've done a lot of research and they will fit, but I've read dozens of opinions on what pressure I should be running on these. It seems to be a universal opinion that 30 PSI is too low for e-rated tires. The sidewalls say 80 PSI max. So, for those of you running e-rated tires on your 1500, what pressures have you found to work best for empty driving and for pulling a 6,500 lb trailer? Thanks for any advice you can provide - I figure this will be a great starting point for me.
I run 45-48 on my 275/70/18s. Anything less feels mushy
Check the load capacity of the factory tires at factory pressure. Then interpolate to the same load given the new tires' maximum load and pressure.
Sent from my SM-G920V using Tapatalk
Thanks for the good info, guys. I'll likely start with Ryan's recommendations for empty driving (45-48) and with 15HDriver's recommendations for trailer towing (65), then adjust up or down as experience dictates. Regarding that Toyo chart - does it apply to different brands (i.e. Michelin) for similar size/load range tires?
I run 40-42 in my LT285/65/18 empty. Per the Toyo link, 40 psi in an E range tire has the same load capacity as 35 psi in the stock P265/65/18 SRAs.
I run what the door plate states when empty. When I haul loads I run mine at 50psi. Seems to work well.
Here's my pertinent data, extracted from the very useful Toyo link 15HDriver posted above:
Weight per tire @ listed PSI
Tire Size Load 26 29 32 35 40 45 50 55 60 65 70 75 80
P275/55R20 111 2094 2216 2315 2403
P265/65R18 112 2116 2238 2348 2469
LT275/65R18 123 1940 2130 2310 2535 2660 2825 3000 3150 3305 3415
...where P275/55R20 was the size that came with the truck, P265/65R18 was my initial replacement tire, and LT275/65R18 is my new tire size. Seeing it all lined up in chart-form really helps me understand things.
As for applying for other brands, I would say yes, as other brands LT275/65/18 should be of the same load rating. And seeing the more broken down chart that you extracted, you can really see how the 45-65 range shines for 1/2 ton usage loaded and unloaded.
On my previous 1500's with E-rated tires, I'd run 40-45 when empty, and 55-60 when towing. That seemed to work well for me, and my tires wore nice and even.
