2017 Silverado Chevy Shake
Seems about normal for a K2 GM truck. Find a dealer that will address it or call GM customer service.
Yet there is no fix right????????????
Mine started out that bad, new tires new motor mounts new shocks then new rear end each "fix" improved vibration a little at a time. I won't call mine fixed and won't say I'm happy but will say it's borderline acceptable. 2014 sierra.
Sent from my SAMSUNG-SM-N920A using Tapatalk
That would NOT resemble anything close to acceptable to me.
Sent from my STV100-1 using Tapatalk
I contacted the ceo of gm. Her exec referral person said there would be no buy back but said i could bring it in for another repair attempt. I've already been told this is within parameters so not sure how that will help
This is a video of my 2017 silverado 1500. GM is claiming this is within parameters...
How many miles on your rig?
How did it perform on the test drive?
That's crazy! Mine has a very mild shake at idle (drops to about 900 RPM and a stop). But doesn't seem right!
My 2016 is as smooth as glass, when did you notice the vibrations? how many miles? what tires are you running?
From what I seen that jumpseat center console only makes it worse, or seems to multiple the vibration, it like a crane with no counter weight, best I could do... its Thursday. weekend get here NOW!.
Do some checking, pull your rear tires and check your hubs some appear to be out of round.
