$100 Accessory Online Bonus Coupon
Krusty
i filled it out, so we'll see what happens. my dealer is about an hour away, so i'd hate to gamble on this and not have it work. if i can't use it at the dealer closer to me
  • Replies 136
My coupon was dealer specific:
"The $100 Accessories Online Bonus below can be used toward the purchase of any official GM Accessory when you buy or lease a vehicle from us. We can provide a description of the eligible accessories for your convenience.
Print this entire email, including any coupons, and bring it to the dealership for redemption."
So how exactly do I use this? Just go into the parts department and show them the email printed?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Yes.........
what did they do different to the coupon when you purchased the truck? Can i do this and not buy a new truck lol?
See above.........
Not really a gamble - if the closer dealer can't look out the window and see U bought a Chevy - U can always print another from the correct dealer - plus a drive.........
Yes.........
See above.........
lol so your telling me i can just walk in... no new truck purchased, and use the coupon.... this sounds too good to be true.
When did u buy the rig - have seen it accepted 5 months later......
I found it easier to use a flat head screwdriver (or if you have a proper pry tool, that works too) to start it at the top. Once you have enough room to get your fingers in it just pops off. Might take a bit of force but you don't need any other tools. Once it's off, you need to detach the safety clip (this prevents the A pillar trim from smacking you in the face if the air bag goes off). Some guys cut it off, but I just unclipped it and then it essentially clips back onto it self to keep it out of the way. It'll make more sense when you see it. Then you just place the new handle over the two holes and secure it with the bolts.
I'm useless when it comes to this stuff and even I was able to do it, lol.
Ordered the handle and have tracking already. Ordered the exhaust tip for 6.2L (3.0") #23435023 - Too many ideas on the 'net.......... LOL........ Couple inexpensive add-ons anyway.........
:chevy:
I'm going to try to use this too even though I bought it 7 months ago. I guess we'll see.
Went to the dealership today. They accepted it after buying my truck 7 months ago. I went ahead and ordered the keypad entry. Not sure where I'm going to mount it yet.
:chevy:
Nice! What else can I convince you to buy now? LOL
Does this have to be a new truck purchase? I just purchased a 2014 Silverado two weeks ago
You just need to go back to 2014....... when this baby hits eighty-eight miles per hour...
:driving:
This coupon truly is a time machine...........
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
