$100 Accessory Online Bonus Coupon
Krusty
Nice! What else can I convince you to buy now? LOL
Fumoto valve if I end up doing my own 8qt oil changes........... Guess it depends on how I like the "free changed for life".......... and the mention of a keypad got me to order another type of keypad - one for my garage.......... Forums, bah! :dunno:
  • Replies 136
Went to the dealership today. They accepted it after buying my truck 7 months ago. I went ahead and ordered the keypad entry. Not sure where I'm going to mount it yet.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Mainly for lock-out entry? How about inside the fuel door?
There must be some "trick" place to have it out of sight - there are a little fugly - reminds me of '80's Lincolns..........
Pretty much for at home and I run out to the truck and forget my keys. Also when I'm at the deer lease and don't feel like having my keys with me and can just leave them in the truck. I've heard of a few guys putting it inside the fuel door but I'm thinking about putting under the mirror so it's not as noticeable. If I had a black truck it wouldn't matter.
Do you have a bed cover? What about putting it up against the top of the bed rail at the top?
Yeah I have an undercover flex so that won't work.
man, i should have used a bad phone #. now the salespeople are calling me up.
Google Voice
Okay I'll admit it!...I was initially skeptical of this whole thing, thinking they'd let me just roll in 10 months later and use this coupon. I was wrong! I just rolled in there and said I want the floor matts and presented the coupon and BOOM! Out the door for front and back for $94.
But now I wonder what is there to prevent somebody from rolling around to different dealers and using this?
Google Voice
lol, that's the # i gave. i always give that one out since it's easy to block numbers.
Thanks - So the extisting cover just pops off starting at the top - with your fingers - no tools required?
I found it easier to use a flat head screwdriver (or if you have a proper pry tool, that works too) to start it at the top. Once you have enough room to get your fingers in it just pops off. Might take a bit of force but you don't need any other tools. Once it's off, you need to detach the safety clip (this prevents the A pillar trim from smacking you in the face if the air bag goes off). Some guys cut it off, but I just unclipped it and then it essentially clips back onto it self to keep it out of the way. It'll make more sense when you see it. Then you just place the new handle over the two holes and secure it with the bolts.
I'm useless when it comes to this stuff and even I was able to do it, lol.
Grab handle arrived today - used a credit card to pry the rubber door jamb seal back enough to grab the plain cover with my fingers - popped right off - no tools - no touching the easily soiled headliner. (Why don't they have black headliners). Then just a matter of lining up the holes - thread on with a 1/4" nut driver as far as possible. Then carefully tightened with a 1/4" ratchet, being sure to protect the windshield from the ratchet handle.
Was thinking I would only use it for getting out - but it seems handy getting in too - no wonder they put them is HD's...... Now I am grab handle symmetrical. :thumbs: :thumbs:
Ordered storage organizer and cover for rear seat and parts guy said they have to check to see if I can use it, yes it has been almost 9 months but there's no expiration date on coupon. I've been a loyal customer buying multiple trucks and my dad but if they dont let me use this thats over with.
So I got my keypad entry installed today. I originally put it under my drivers side mirror, but it looked horrible. Especially since my truck is white so I came up with another option. I installed it on the wiper cowl close to where the vin and the windshield are. I'm happy with it and you don't even know it's there unless you're looking for it.post-54656-149100825065_thumb.jpgpost-54656-149100825864_thumb.jpg
Drove down to my dealer today and picked up the front and rear molded mud flaps, he had both and said total was $115 including tax so I handed him my coupon, he took a minute to write the VIN number on it and said I was good to go. I ask him who to pay the extra $15 to and he said I was good to go and they would adjust the price to $100 total. Now I got to figure out how to make a homemade riv-nut tool. Dang Engineers could of done several different options to install these but nope, need a tool for the riv nuts.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
