I have searched every forum I could find be and could not find the answer to what I was looking for. I bought a 2015 Silverado crew cab with a levelling kit already installed, so I am unsure of the levelling kit height. From the ground to top of all 4 wheel wells measure 38 3/8". Most posts I find have guys using a 2 or 3 inch rear block depending on the size of their levelling kit. I would like to add some rake back to the truck so the reAr end isn't lower than the front when towing my ATV or boat. From what I can gather the factory block is 1.25". Does anyone have any opinions on what size block? Is a .75" rear ended lift enough? Will a 1.75" lift be too much if I use a 3"?
Does a 3 inch block actually provide 1.75" of lift over stock? Can I just jack the rear of the truck up .75" and then 1.75" to get a feel for what it would look like?
The readylift 2 inch block I just installed is actually 2.25 inches and provides a full inch at the rear. It's enough that with a few hundred pounds in the bed, I sit level as opposed to squatting. With an empty bed there is a nice amount of rake, but not the excessive factory faceplant.
I personally would not have installed a new rear block with just a 2" front level, but I'm at 3 inches in the front and I'm happy with the results
Edited by Bushleaguechew
  • 9 months later...
I was seconds away from pulling the trigger on the ReadyLift 2.25" blocks in conjunction with the Bilstein 5100s, but all of a sudden started coming across this issue with those rear blocks being tapered, and driveline vibration issues.  ReadyLift website isn't clear whether they are tapered or not, and other retailers carrying the kit conflict; some say tapered and some say not tapered.  Any chance you can confirm whether yours were?  And have you had any vibration issues since installing?
Thanks!
Thanks!
My truck vibrates at 75-85. Can’t say for certain if it’s the block or not. I don’t believe it was tapered but I can double check later.
Thank you sir.  I finally just got ahold of ReadyLift direct and the gentleman I spoke with told me they are NOT tapered.  He seemed to be answering from his own personal knowledge/experience and reassured me they are flat.  Still skeptical, I went in and downloaded the PDF installation documents, and sure enough, it specifically states and illustrates pointing the tapered-down side toward the front of the truck.  Sigh.  Let me know what you find later on when you have a chance, I really appreciate it!!
Welp, went ahead and ordered the RL 2.25" blocks which arrived. Of course, even after I was reassured directly by RL these blocks were flat, they ARE tapered. Albeit small, the taper is 1/8th inch, from my understanding of pinion and driveline angles, this is a sure fire recipe for driveline vibration issues. I can't believe these companies manufacture parts without understanding the need for the driveline angles to cancel out to ensure rotations stay constant on each side of the drive shaft.
Is your a truck the 2015 2500 in your sig?  Install them and see.  If you experience problems, Tuff Country sells nice flat 2" block with ears for 2500s.
  • 3 years later...
I installed readylift 2.25 rear blocks (# 66-3002) about 2 weeks ago. I can confirm they do have a very slight taper which you install pointing the taper forward.
With the U-bolts tightened down, it appears to sit flat & flush against the leaf spring.
In the limited amount of driving since then, I haven't noticed any vibrations at all.
Edited by YYC-SIERRA
I’ve had the RL 2.25 rear blocks for about 9 months and I don’t have any vibrations in the truck.
My front is leveled with Bilstein 6112s on the top notch. I have a Leer topper on the bed and the truck looks level. I need to measure it for sure, but I am wondering if I would like it a little better with an add-a-leaf to get back a little more rake.
3 hours ago, Mike Genther said:
i have a 2015 chevy silverado with 7 inch rear blocks no one can tell me what size lift i have
Stock block is 1", your lift is a 6" and, hopefully, you don't have stacked blocks.
Edited by MikeBMW
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
