upgrading brakes
i want to upgrade the brakes on my truck 2016 silverado 5.3 z71 4x4 I'm looking at the power stop z36 truck and tow brake kit. replacing the pads and rotors witch are drilled and slotted has anyone had these ? how much of a difference where they ? i do town an enclosed trailer 7x16 about 3000lbs . if not the power stop any other suggestions on brakes ? unfortunately i can't afford the brembo kit that chevy offers
https://www.realtruck.com/power-stop-z36-truck-and-tow-brake-kit/R184385P2016Y734MA.html
I have them on my '14 silverado, I also tow a car trailer now and then. Brakes feel fine to me. Ive had cross drilled and slotted rotors on many of my cars and these actually are the least noticeable. Usually you feel the rotors when you apply the brakes and I went thru the pads very quickly. I sold that pad/rotor combo to many of my customers when I sold domestic/import parts, I never really heard any complaints about them.
  • 4 weeks later...
I'm also looking into the Powerstop brake rotor and pad combo. '15 has 46,000 on it, rear is at 3/32, front at 4/32, but getting some noticeable pulsing at mild pedal descending down hills at normal driving speeds. Guessing I probably have another 10-20k left on the stock brakes.
Pulsing is lateral runout in your rotors. It's typically caused by consistent over-torqueing of wheels (especially common on European cars) and/or getting them pretty hot and happening to drive through a puddle or something that rapidly cools the metal. Chances are you'll be able to have them machined with no issues. Just keep in mind, the thinner a rotor gets, the more prone it is to becoming warped again.
I read your post, and without shelling out money for the Brembo kit, it seems as though a pad upgrade would help. Maybe hawk makes a solution for our trucks?
DM if you have any questions!
-A friendly mechanic
I had the truck serviced today (one thing I don't bother doing at home anymore are fluid changes, major pain in the neck getting rid of waste oil). Any rate, asked them to take a look at the brakes while on the lift doing a tire rotation. Talked to them further after I posted, said same thing, rotors have runout. So question is, what to replace with. Has to fit within the stock 18" wheels, I'm not dropping $$$$ on aftermarket brakes but am interested in possibly drilled and slotted rotors with good pads if will help. I did a brake upgrade (stock rotors with aftermarket pads) on my '05 Avalanche back in 2009-2010 (sold it in 2012), don't remember what we used, I do remember the brakes were noticeably better than stock though. Will look into HAWK pads
I'd also look into EBC. They also have high quality rotors and make a heavy duty towing pad
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
