Please watch/listen to this video. This is not my video, but my truck is making the exact same noise as the one in this video.
Please read the video discription, it is the exact same thing as mine, starts loudest at cold start, then fades away, but not totally away in mine.
I haven't really checked it out yet, just wondering if any of you have already come across this particular noise, as it is a very distinct noise. Kinda sounds like an old grandfather clock tick/tocking. Thanks.
Edited by 15_silverado
My 16 5.3 makes the same noise. I was just wondering the other day what that was as I don't remember hearing it over the first 10k miles.
The chatter noise is the direct injection. That metallic clank sound is probably something in the belts. It sounds like it happens once per revolution of the accessory drive system.
Valve lifter knock or injector, this will occur until valve lifters fill with oil, as they leak down when engine is at a 4hr cold soak. They fill within 30 seconds of running, but sometimes if there was traped air oil "foaming" they can make a knocking noise for closer to a minute.
It sounds like an engine rotational sound, it could be the tensioner pulley?
Listen at the front of engine with a hose, then the valve cover to close in on the sound. Do it when the engine sat cold for 4hrs though.
Thxs
I really don't think it's anything to do with the lifters or valve train. And it's not a normal DI sounds. It sounds like an accessory to me, most likely the vacuum pump. I just haven't had a chance to check it out yet, I'll put a mechanics stethoscope on it to narrow down where it's coming from.
It's a distinct sound, that's why I was wondering if anyone had this.
Thanks all.
If you go to the dealer for this, or figure out what it is, please let me know.
Thank you.
Thank you.
I've been to the dealer over 20 times in 9 months for this truck. If I come in and tell them I hear another noise they will tell me I am crazy. I noticed it this morning when it was cold start, but didn't hear it once it warmed up. It is a distinct noise with a pulse about once every 1/2 second. I would think it was just normal if it had always made this noise.
Edited by ShamrockShooter
I hear you. I got a mechanics stethoscope coming, I'll poke around with it to narrow down where it's coming from. I'll let you know, but it may be a while.
It's probably not serious, but it can't be normal because not many other trucks make this same sound, or more people would have commented on this, it seems we're just lucky!
Oh, and the guy that originally made the video hasn't answered any comments/questions on it, so I don't know if he ever figured it out.
Lucky? Sure. I guess that is one way to look at it... lol.
I first heard it when I was checking for exhaust leaks from my new exhaust. Sounded real loud when your head is under the truck near the front of the exhaust.
I had the same noise(squeak chirp) on my 2016.
After numerous attempts this is what my dealership found. And it fixed it.
I know this is an old thread, but has anybody determined what this sound is? My 18 makes the same sound.
[mention=126037]Haider320[/mention] I was just going to send you a message to make sure you saw the video in the first post. It certainly sounds like what you were describing by a blinker type noise. The post above yours says they replaced the high pressure fuel pump and it fixed the issue for another member who was experiencing the same noise.
Yes, thanks.  I just read that.  On the YouTube link, there are several guys saying they have the same sound. Either GM has some faulty fuel pumps, or some of them just sound like that. My best friend has an 18 and he says his makes the same sound like mine.  Kinda like the vibration issue.  Some have it, some don't.
Edited by haider320
