Hi everyone
I need anyone's help, please.
I've taken my 16 Silverado 5.3 into the dealers twice. The sound is a tick similar to a sewing machine.The sound is coming through the firewall near the foot pedals. It makes the ticking while driving in the city and on the freeway. I can be cruising perfectly and hit a bump and the ticking is triggered. The ticking increases in speed with even a slight acceleration. I'm thinking it's coming beneath the engine or under the driver side.
The first time in to the dealership they replaced the pressure pump but didn't do anything. Today they replaced a fuel line that seemed to make the ticking more often and louder.
I drove around with the service tech and we both heard the same noise and he said that his exact truck that he was using was making the same noise and it was normal. However, I test drove two Silverado yesterday. A new 17 and 16 with 11k miles. The 17 was silent but the 16 had the same tick but very faint and nothing compared to the noise on mine.
I plugged in a Range thinking it had to do with the AFM but didn't make a difference in the ticking.
I'm a novice when it comes to trucks so I'm in desperate need of help finding a fix. I'm really considering getting rid of the truck. I really don't know what else do it. I really wish there was a fix that didn't involve an exhaust or having the radio super loud at all times.
Hi everyone
The only 2 things that can make that sound and noise are fuel related. First being the injectors they are alot louder now then in past years, but I think your issue is from this the other possibility....the fuel return line check valve.
It is at the back of the engine and runs against the engine bay / cab wall middle of instrument panel.
It is known to be loud while ticking away at engine rpm. This could be removed and insulated to reduce this unpleasant noise.
Take care and good luck!
Mine does the same thing. I can hear it clearly outside the vehicle but not while I'm in it.
I think all the direct infection motors have loud injectors now. I remember thinking something was wrong when I first bought it.
  • 3 years later...
On 5/24/2017 at 12:21 AM, Dmendoza said:
Hi everyone
Any update since last posting? I’m having a similar issue.
Edited by Nick West
Welcome to the site, try this thread:
This was my guess also. The old greasing of the steering shaft boot........
Wonder what kind of response (and pricing) you would get if you posted that on Craigslist????
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
