Again thanks to@pgamboa for all the help with chasing wires and locating pieces I needed.
  • 3 years later...
@Csjumper2003
I'd be very curious what option truck you're staring with (I have an LT1) and what was in place.
  1. What is the part number of the fuse block you installed?
  2. Were the wires between the driver's fuse block and the plug for the over head console in place?
  3. Were the wires that go from the overhead console plug to the instrument panel in place?
  4. Where the wires that went from the instrument panel to the rh fuse box in place?
  5. Were the wires that went from the rh fuse box to the <motor location> in place?
I can't imagine #5 was present. If not... did you simply have to add those two wires from the fuse block back to the motor location? Pictures would be awesome.
I just swapped out my overhead console for one with HomeLink and it also had the rear window button. A button that does nothing is not sitting well with me. I'm just glad I didn't buy a console with the sunroof buttons, too.
Edited by David W S
6 minutes ago, Anthonyvee90 said:
titan window
A window out of a Nissan Titan?
4 minutes ago, Anthonyvee90 said:
Yes
Interesting, didn't know that a titan window would fit
15 minutes ago, PFTX_5.3 said:
Badass, I spot a mirror camera too
good eye
Mirror-says sold out but if you message him, he’ll sell it to you.Mirror
Camera-Part#84486910
Cable-Cable
3rd brake light Gasket-Gasket
3rd brake light still works
Edited by Anthonyvee90
added pic
7 hours ago, Anthonyvee90 said:
wired to oem switch
I would like more information on the wiring to the oem switch. I am planning on doing this and was going to wire it to the oem switch myself.
Sorry what I meant to say was wired to oem switch location with after market button. Wired to oem switch but wouldn’t work 5 pin usually is
pin1:window motor
pin2:ground
pin3:12v
pin4:ground
pin5:window motor
but couldn’t get it to work if you figure it out let me know please
12 hours ago, Anthonyvee90 said:
good eye
Cable-Cable
I've thought about it but I rarely use that mirror, my first car didn't have one so I got in the habit of only using my side mirrors
pin1:window motor
pin2:ground
pin3:12v
pin4:ground
pin5:window motor
Will do. It might be awhile before I get to that the 2014 is nearing time for a new engine. I'm saving up for a l8t swap.
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 465 Guests (See full list)
