Thinking of these wheels
Man that looks bada$$!!
I'm not a fan of polished stuff.
I would go with them. It looks mean that way, and different from all the shiny-hineys with them flashy wheels. :sigh:
No offense to those of you that like shiny things, of course. :thumbs::thumbs:
I had to take a double take. I thought that was a Dakota RT for a sec. Those wheels will really set it off right. Definatly not the norm. Definatly worth it. Has that sleek mean look to it. No matter what anyone says. DO IT!!!!!!!
Later,
Brandon
need some more bling, those just look blah to me
plus the spokes don't look like their big enough to even hold up a motorcyle
Hey, I'm 44 yrs. old... I don't bling nothin'. You can keep them big wheels. Makes your truck look like the toy pedal car that I had when I was a kid. I want to see some rubber on my vehicles. These 17 inchers are plenty big for me. Here's a closer look at the rims, so you can see the size of the spokes. They don't show up good on the pic of my truck.
BTW, if I get them, they will be the polished ones, not the chrome.
Your not the only one n8 I don't like em either
I keep my big wheels that bling and grab every girls attention as I roll down the street with all the awards I've won.
Wish I had a pedal car that looked as good as my truck on my dubs
Once you roll the big bling you can never go back
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
