1SLOW1500's Turbo truck build
1SLOW1500
24" 295/35/24 they rub the carpet in the front. But it is very little and doesn't hurt anything
Got my ups tracking info BMF turbo will be here tomorrow.[emoji3]
Sent from my SM-N950U using Tapatalk
  • Replies 354
Nice turbo. I'm happy.
Tune is so close truck lights up the tires all the way through 1-2 and then I let up.
I will need to soften up the traction bars.
Still playing with this turbo and tune but trans is so tight the hit on shifts jerks you head back and barks the tires. And this is low boost 8 and less. As I was on spring only.
Dyno will be mandatory as I need the max tune with no spin. Then I can use the boost controller like a TC and progressive boost control. Should give me traction.
Hope new turbo isn't as aggressive down low. f8bb7bcd85a2022027a91f7e7a257e3d.jpg
Thought is was large for a t4 then I compared it to the air hole for his big brother and it looks tiny. 76/75 vs 98b572e63d23d6351fe5e6279a55e6e7b9.jpg14e6422dbf73668f8d38b5737f7f80a1.jpg
Ok so I was having a issue with heat coatings on my turbos. My twin turbo Camaro had a ceramic silver coat and in 3 months it was all burnt off. Last coat on this truck was 90% but still on the way out. So new turbo I looked into a popular coating I used in my other hoppy of firearms. Cerakote coating. Even a air dry coating is rated at 2000*.
Want to see how this works on a 6.5" ak47 barrel with a flaming pig and in full auto. Then I would have the new suppressor coated as they take super abuse.
Anyways takes 5 days to air dry, so next weekend I will swap it out.
Dealing with some weather and tuning here but all is well and truck has never been so fast.7802e38a1c7803c6809d5ecd188396e6.jpg401cd23f6e7fa10447f6bf7edb9232bf.jpgefdfd6e7ffc5b1333c7dd9b4ab8ab64d.jpg07ae305d73bbbc937f072932a11b330d.jpg
Turning wrenches. Redoing drain and heat shield, some boost lines,and rvt on v bands and header.
Funny new turbo doesn't look much bigger but is.99758db9ed7fa23c66ece57d5cd504ec.jpg8f8d8129c93165f9c5350436e4520f8c.jpg8cece21d81e095e0a6acbdaefbe1f98a.jpg
FAIL. So few issues the new turbo is a 3" outlet and my setup is 2.5" so needed a silicone 90*. Had to wait till Monday but called on3 and as always they sent it free no questions asked. Also the down pipe doesn't line up. As it was modified to fit the Borg Warner turbo. So I will need to get some 3" stainless and start up the welder.
So this weekend back at it. Pics to come.
Got the new elbow installed and re clocked the compressor. All that is left it the gap in the down tube. So I will pick up some stainless in the morning and get to cutting and welding it up.
Need to remember to prime the turbo and to re align the crossover pipe. May need to come up with a way to limit the expansion on that.
I will take this till I run out of fuel or once the dyno reads 650rwhp. I will need yo retune the baro settings as it is already freaking out. Then dyno to finish it off. 1811282c17157b032c0392a195b310b3.jpg20236fe8ffae97ff96170aba9e20799b.jpg
Ok it's done. Had the normal oil leaks, drain and feed at turbo. Quick fix. This turbo exhaust housing is a little bigger so at idle the turbo is just spinning slow. Hope that raises my boost spooling point to over 3000k. As the other turbo was just too quick, even more so in daily driving with the always shifting 6 speed. Still need yo redial it in will the new turbo but that's easy.
Note the oil drain is tricky on a turbo it is high and back in the pan but with a full 8qt. And my additive oil is at the drain when truck is nose up or on a hill. Worries me with draining. But never pushed through the turbo or leaked.
This Hiwow company makes cheap heat products but the quality is amazing. I was going to buy the dei because I used it on my car and motorcycle but the turbo blanket was $381. I paid under $30 and free shipping came in two days and looks cleaner. Covers everything I cant even see the turbo exhaust housing at all. I will have to see if that drives up the internal temp. As at warmed up temp I am at 900 on expressway 1000. Need more heat in it.
Will say this turbo is 3 times louder. Only pushing spring pressure right now so 8.7psi is peak. 7501dfe60e50a36b5bdcffd3bedb5510.jpg
Well that escalated quick. Redid my tune for the new turbo and ran out of boost. I was seeing a MAX of 12.9psi. With the as shipped 6lb wastegate spring and my controller at 5.1lb active 95% duty and 15% gain. I could up it  to 100% on both but I think I would get boost spikes. So going to order the 8lb spring for 16lb boost. Wonder if I should just order the 11lb now. Also think I may just get the driver side stainless header. I believe it flows better but question if the difference noticeable.I could buy any head that is stock y pipe compatible, but the ON3 is 2.5mm thick stainless.  Oh well give me something to do.
As for fuel I will get a set of LT4 injectors and pump also a shim. A cam can bump it up but I read this is better for my power goals 650whp. And "if" I want more a cam on top of that, people say 950-1000rwhp.  Need about 30% more fuel for a E85 tune at higher boost.
Do you still have the stock connecting rods? I’ve seen a couple videos (and maybe you’ve already mentioned it in this thread) that they are a weak point when pushing the HP above 500.
Yes I do and I have a back up motor. But rods are good till 600-650rwhp. Or so I'm told by reliable sources. Lot of 600rwhp and lower trucks out there. Tune and back pressure and iat is key. That is why the breakout maf and talk of meth/water or e85.
So more silicon line is ordered in case I see waste gate surge I can quickly change the source line to the controller out port. Dangerous? Maybe but have to plan ahead. Ordered the 8psi spring.
Was going to order the stainless driver side header but for whatever reason it said it wasn't for the 2014-2017 trucks so bought a set of stainless shorty headers. I will pick them up today.
I will do a solid no spike 15psi tune and data log all the fuel tables for  a few days.
THere is a local shop that is having dyno day. I think I will go and see what happens. I know I will not win the most power as there are fully built cars/truck there but fun day anyways.
Still trying to get part numbers for GM factory E85 conversion. Need the right part # as it will take 3 weeks to get from a family member for free.
Also may need a helper bag as I'm taking to a shop in NC to take my drag car and build it this winter. So a trip would be needed and I'm lowered with no 3rd leaf spring.
Damn this is one of the reasons i wont do a turbo.
I hope it all works out but i couldnt do all this
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
