Pex catch can hose
joshc64311
What problems would I run into using pex tubing for the catch can hoses? The hoses that came with my elite can seam to be leaking.
I have 10ft of pex laying around, and I've had my can for about 2years I doubt they would send me some more hose for free
Yah PEX would really struggle with the heat and flexibility needs. Just grab some vacuum rated fuel hose.
I used a high pressure fuel hose when I installed my Elite catch can. It was the only hose that would not hiss or collapse due to the vacuum in the system.
Has this always been a problem with Elite?  If they cant sell good hoses with their system makes you wonder about the guts of the can.
It does make you wonder..However, I have been very pleased with the can itself. They do need to step up with the quality of the supplied hoses.
Does it have a filter on the inside? I hate the cans that just come with 2 hoses and a drain. Kinda pointless. Really needs a filter.
On 11/11/2017 at 10:53 PM, carnau said:
Pex hose maximum heat is 180 degrees. I would say no unless you want a hot mess.
Some HPS would work and it comes in alot of different colors.
Clear - http://amzn.to/2hsTsgi
Red - http://amzn.to/2i5eyOG
Blue - http://amzn.to/2ytYdJs
Black - http://amzn.to/2zDe364
  • Hose Inside Diameter: 3/8" (9.5mm). Length: 5 Feet Roll
  • Made of High Temp Premium Grade Silicone. Meet and exceed SAEJ20 industry standards, ideal for heavy duty pressure connections and provides excellent resistance for high temperature applications
  • Great for marine and industrial use, custom turbo or intercooler piping fabrication, DIY intake or radiator cooling system
  • Heavy wall design gives it the ability to handle extreme pressure
  • UV and ozone resistant. Silicone hose is NOT compatible with fuel or oil ****************
Correct. You are not running pressurized fuel or oil through the system for a catch can.
