Light bar into the fog lights is a nice touch, smart.  And the upper ones are pretty much on all the time then, right?  That's what I'm hoping for.
I'm a complete newbie with electrical stuff more or less so bear with me.
What he did was place all 5 lights onto the grille and wire them together. Then you take the closest one to either side of the headlight, find the parking lamp wire and splice the positive into the parking lamps. Then you ground the other wire. I'm basing all this on the assumption that the lights are only positive and negative.
  • Thanks 1
Not a problem, I totally understand. Yes sir that’s correct. I’m not sure if your truck is the same as mine, but I’ve noticed during the daytime the parking lights don’t come on with the daytime running lights but when it gets dark they do, so the grille lights of course will be on then. Which in the daytime unless you’re right in front of it they are hard to see. But in the night time they will definitely bring a smile on your face lol
Correct, there is only two wires. I did the driver side headlight because it’s WAY easier to access when everything is said and done
I went ahead and bought a few of these when I saw your first post, but haven't figured out where to put them on my Sierra grill yet (different spacing/holes and all that), do they are still sitting in my toolbox [emoji53]
Do you have a picture of your grille?
It's just a typical Sierra SLT grille. I was going to try and put them at the top right between the thick chrome surround and the top of the three grill oblongs, but they are too wide to fit there. And I'm not so sure I want to put a plastic piece all the way across the oblong section right above the GMC. Perhaps I'll drop a little piece of plastic down into the gap, just enough for each LED. afc0679fe6ff363f43a96449282c51af.jpg
That’s what I’d suggest, to prevent headache I would also get everything measured and marked, then drill them before you put them on the grille. But that’s exactly what’s I’d do. Make some some little squares that come down just enough for the led to fit in.
What, you don't like the wing it method of drill thrice, measure never?
Lmao I’ve wasted too many cuss words on that method [emoji23]
2 hours ago, BlueTopaz14 said:
Now that you got grill lights. What's next ????  looks good
Thank you!! And I’m thinking either an aftermarket hood, or a rear bumper, plus I still need to have the roof light bar installed, it is currently collecting dust lol
WHEN installed  need photo's . Please . Note - you will get a wind noise from the light bar .
I’ve had lights like these installed on my truck for awhile now. Never got around to posting pictures. Don’t anybody steal my design [emoji135]‍♂️ e530088fbe52e79ac0c4f9253662164b.jpg78560612311d02d0d4fc0a8821203194.jpg
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
