I want native Nav back!!! Help
Rukus
Correct. My 2017 LT has factory NAV. It’s RPO, IO6
As far as XM weather goes, I refuse to pay them more money for it. You can install the weather channel app directly on the mylink system and it does everything the XM weather does including hourly, multi day forecast and radar. And it’s free.
I did switch to the unlimited (for additional reasons as well) however, gets throttled after X amount of data.   GPS uses a large amount.
16 hours ago, newdude said:
I went on the link... I see nothing listed that say they offer Native Navigation.   Only the Onstar Navigation.   The IO6 simply says Navigation but that is the EU1 (ONStar Nav).  No?   Per the dealer  and parts/service this is true.   I'll grab my build sheet in the AM and confirm.
The columns on there are the trim levels.  Stay in the 1LT and 2LT columns, and then go down till you see IO6.  You will see an "A" in the box for 1LT and 2LT trims, which means available.  Nav has been available on LT trim 2014-2018 trucks since they started production.
Here’s how it looks on the sticker and build sheet.
On page 2 they list UE1 also, which references the onstar service (5 year basic, 3 months of everything)
Yep... I have that listed and the Nav is OnStar ONLY.    No Native Nav.
So for the sake of clarity, you are saying your truck has I06 option per your glove box build sticker and the window sticker  shows the $495 option.
Sounds like the OP just doesn’t have the option. It was definitely available on 2017 LT’s.
If that’s your build sheet and window sticker, it sounds like something is wrong. I06 is most definitely what you’re looking for if you want nav without CarPlay or onstar being required. Is it possible the nav icon is on a second page of apps, by chance?
If you have I06, I’d be talking to my dealer right away. The RPO is the same for a high country as an LT. if it has i06, it should have navigation.
19 hours ago, 15 Z71 said:
Just got off phone with xm,it will not work because I do not have built  in nav. Bummer.
I can understand if the Traffic part of it doesn't work without the Nav but the Weather part should work fine (it's a separate app and icon on the screen).  The only reason I can see needing Nav to use the Weather is for it to get your location but I think you can enter that into the app.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
