Got my 295/70/18 ridges and 2.5” level put on today. Anyone else running this setup? Curious how bad it hurt your mpg and if you did anything to help the slight rubbing at full lock?
  • Like 4
It's certainly not going to be easy on your fuel mileage lol...
No I can’t imagine it’s going to be easy on it. Lol I was getting 18-20 before. I bet it’ll be 15-17 now but who knows.
Keep in mind your dic is now off, because of the tire size change it won't give you a true reading. Not that it's accurate in the first place. If you hand calculate it after correcting for tire size change, you'll get a true reading of mpg.
7 hours ago, Daly said:
I wouldn't be surprised if 14 is your new best.
It should get better than 14. I have a 6" lift and 325/60r20 KO2s and get 16 mpg average on 87.
As for the OP's question about rubbing, just find where it is rubbing and trim a little bit. I pulled the fender liners back on my truck and it fixed the rub I was getting at full lock in reverse.
I think this is what I'm going to run next, I currently have 275/70r18 with 2.5" Level/lift and an AAL.  I get aboud 15-17mpg in summer (I work the truck hard though), and have no rubbing issues.  As AdamJ said, just do some investigation on where it does rub and you should be able to zip tie the liners back.  I'm curious if you do trim or anything post some pics up.  I'd be interested to see how they look at full lock.
I have been getting 16ish with 35s and a 4 inch lift on my 6.2. I haven't corrected but accounting for a 7% difference I feel I am in the ballpark.
I'm running 295/70R17 Ridge grapplers which works out to about an inch smaller height but same width, my guess is you are rubbing at the minimum the inner fender, easy fix there.  Poke a hole in the fender liner and pull it back with some zip ties.  Also trim the corner of the black plastic cap with a utility knife, you should see where you are rubbing.
The driver side has the e-brake cable that you might be rubbing on as well.
Edited by aaronarf
Thanks y’all. I can post some pics at full lock soon. I’m getting about 15 on the interstate running 75 and about 16-17 on highway running 55. Driving in town is a terrible 11 or 12 mpg.
I have had this exact set up for about a year. I love it. I drive 60 miles to work and back home every day. The Nittos are wearing evenly and haven't gotten any louder since I put them on. Good choice and your truck looks awesome. Makes me wish I'd bought white.
Thanks! That black looks really good too.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
