clean looking strobes
xps800doo
just purchased a 15' 2500 SLT Duramax  looking for ideas to add yellow caution strobes for my lawn care business.  I don't have the garage height nor do I want to add a roof mount strobe was hoping somebody has done something clean(behind grille? flush mount in bumpers?)  and hard to notice until they are turned on.  of course not being roof mounted i would have to add something front and rear facing.
thanks in advance!
I have amber/white feniex cannons.
a set in the reverse lights, a set in the third break light (white part)
a set in the grill, a set in the fogs
Dont notice them at all until there on. They also function as my reverse lights, bed lights, and fogs, as normal
Heres a vid...
https://youtu.be/MnXRCmAdUT8
Heres a vid...
Did you have to drill into the light housings? How did you decide where?
Found and read install instructions on their website, they say to drill a 1” hole...
I use them as a complete bulb replacement. I used a unibit to make the original bulb socket hole a one inch round hole. They are three mode so you can use them as normal lights also. For me it was a win-win because I got strobes, and really bright LED reverse lights now. Same goes for the bed lights and fogs
How difficult is the wiring to do that?
pretty easy, set mode 3 to steady white burn, hook the mode 3 wire to the + of the oem reverse light wire. Mode 3 overrides mode2 and mode1, so basically if my strobes are on and i put it in reverse, the reverse lights will override the strobes and come on solid white.
