Higher Octane Fuel Hurts Transmission?
For the past 2 fuel runs I have used 89 octane instead of the 87 that I normally use in my 17 5.3 Silverado 6 speed auto. The shifting of the transmission has gone down the toilet the last 2 fillups. I am almost out of the second fill and going to go back to 87. I normally drive pretty smoothly and know that these have a learning ability to the transmission. I've had some rough shifting that has occurred off and on but has gone away as I've calmed back on my driving habits. However, this feels different. It feels like the shifts are just off. They aren't well timed. When flooring it in first to second it just doesn't shift in time. It is a slow shift into 2nd and you feel the lag before it catches the next gear. The truck does feel underpowered.
I know that higher octane fuel is better for higher compression engines because they combust later. I am wondering if the higher octane fuel is killing the power of my engine and throwing off the shift points? The only mod I have is the Airaid tube (still have regular filter). I don't hear any vacuum leaks coming from the engine.
Any thoughts? I was planning on unplugging battery after I fill up again with 87 to see if it gets back on track.
Higher octane has nothing to do with the way your transmission shifts.  I would just run 89 if were me.  Talking to several tuners, they state that these engines benefit from the higher octane and wouldn't go lower than 89.  Makes sense with the higher compression ratio that we have over the old 5.3's.
If the shifting gets worse then you have other issues, basically something wrong with the transmission.
I’ve run various tier 1 octane grades for multiple successive tanks.   And I had an 8 speed that had indigestion the entire time I owned it.
Zero correlation.
I had ice cream the night before I was diagnosed with a brain tumor. Therefore, ice-cream causes brain tumors. While a true story, not a true scientific conclusion.
Sorry to hear of your plight Rob.
Low octane fuels generally speaking cost more to use.  They deliver lower fuel economy and lacking the additives that benefit the fuel system and valvetrain, do not contribute to an engine's longevity.  You want to see a difference in performance, engine idle, mileage, etc. run 91/93 and never look back.  And if you have a yellow gas cap, don't deprive your motor the pure enjoyment of running E85.  If cheap enough, it costs less per mile to run than gas.
1 hour ago, Rob Okray said:
Causation does not indicate correlation.
Other way around.
Correct, correlation does not imply causation.
While we're on the topic of high school statistics class, do you think there is a lurking variable causing the poorer shifts and it's not actually attributable to the higher octane?...or maybe this is the placebo effect (in reverse)?
To be serious though, were any other mods done lately? Was the 87 and 89 gas from the same gas station? Significant ambient temperature difference lately? Warm up time the same before analyzing the shifts?
1 hour ago, Mileguru said:
Other way around.
I blame the tumor. Poor shifts. Going to blame that on the confuser, or the sensors giving bad info to the confuser.
I find it hard to fathom that any of the newest gen trucks have enough abuse for sticking shuttle valves or out of adjustment bands etc.
Even my 07 with 108k and my 91 with 230k were smooth as glass with shifting. Both auto and both on the original trans.
Thankfully there are no bands in the 6 or 8 speed transmissions.
There ya go. Bob's yer uncle.
    CockneyUSA
    CockneyUSA
  • Who's Online   4 Members, 1 Anonymous, 756 Guests (See full list)
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
