13 hours ago, KD5FPV said:
Same here.  If you do it before I get mine done take a pic or two of the hole you find.
Found one! Don't know where there are drains in the other cab layouts, but my single cab has one right at the back corner. I drilled a ¼" hole in the plug for the cable to run through, and then gave it a thick dose of black rtv to seal it up good.
Thanks for the inspiration to finally make my installation a little cleaner lol.
5a9ab5ea9f827_IMG_20180303_0940056452.thumb.jpg.24ccbd97184ced009b4d2309658ed8ba.jpg5a9ab5f3b00e6_IMG_20180303_0943551852.thumb.jpg.7ab143cbb65901881cbc198084c8b415.jpg
I like it!!! Don't see why my crew cab won't be the same. I can't wait to get mine fully finished!
Sent from my BBD100-2 using Tapatalk
And mines a double cab I'll check it out soon.
Is there much radio traffic on your  " CB Radio's" these days .
On 2/27/2018 at 8:58 PM, rocnrol said:
Pretty much every truck I've owned has had a CB. But these trucks with a full console make it tough to mount one nice. I think I like it like this, with the mike hanger just below the seat heater switch emoji6.png306efe5df92052c36596c04e44206943.jpg395ce815dc07e36146bc554122985a46.jpg
How does the speaker sound where it is?  is it muffled?  How did you get the cup holders to slide forward like that?
Tooch,
It isn't fully hooked up yet, so I can't say how it sounds yet. I do have an external cb speaker in case. As for the cup holders, just grab it and give it a good pull up. They're held in place by some spring loaded balls. You'll be surprised to find another huge space underneath it, and probably a bunch of stuff you lost [emoji6]
The crew cabs do, they are under the rear passenger's left foot...big oval plug.
Steve
Sent from my SM-G950U using Tapatalk
 As for the cup holders, just grab it and give it a good pull up. They're held in place by some spring loaded balls. You'll be surprised to find another huge space underneath it, and probably a bunch of stuff you lost emoji6.png
Has anyone been able to move the cupholders on a '16 or newer?
AFAIK  '15 was the last year they were moveable.
Here's what I've picked as my antenna location 0bf238e3cd54839c75cf0db9650c6afb.jpg63dac96198870c816e9f41ebda99c6fe.jpg4ef871026193e1984a38d0eba5837d4c.jpg
Should give you a good counterpoise as long as the antenna is grounded to the bar well (assuming the bar is steel). It will use that bar as a counterpoise...
I did a Wilson 5000 mounted center of the roof of my crew cab (hole drilled, not a magnet mount). I'm running a General HP40W barefoot, the antenna gives me a nearly flat SWR of 1:1 on all 40 channels.
I ran a 102 inch whip on the last truck, and over 850 watts...May not even put a radio in the next truck, there is very little (quality) traffic to speak of anymore...
Sdeeter,
You definitely seem to have a grip on setting these things up!! Lol. I agree on the grounding of the bar, I was going to check that for sure. I've always had someone else tune my antenna and radio.
I agree on the actual use ability of a CB..... To be quite honest, my primary drive is "the look" use is secondary [emoji12]
I put my little cb in the cubby where the cd player would be on GMT400s,fits well.Not a lot of range but works well when off roading with other trucks.Magnetic antenna with cable going down the rear door jamb behind the rubber seal.
It was a pretty nice weekend here, so I was able to get this job done. I might do something different with how the antenna gets to the radio, and how the power cord gets to the power port.
It took some messing around with the mounting stud to get it grounded right, and then some tuning with the antenna, but, using the SRW built in tuner, I got it pretty close to 1.5 on both channel 1 and 40, the picture shows where it is on 19.
I fished the cable in through the cab vent on the back wall, then fed the cable under the door kick panel. ecc60b1846bca18d130d62d7d91d99da.jpgc75e1a933d298efb5d8e53ae2f5a3c3b.jpgd00ef768cb45352db61459cf1e8906fe.jpge7bcb8376723650f35356537ad0c86e1.jpg99e6cf8a9559f2106f12d3c3559ae55e.jpg75279051480f78a76b8ce25367336b27.jpg439e91793eeb199426b88dfd5f7e90d6.jpg95e1a64792306b54d078f106706200de.jpg
    250.6k
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 238 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
