2018 Navi system map update
On 3/23/2018 at 10:50 PM, 2009GMC said:
How does the speed limit work? Does that require OnStar subscription or just need the factory nav? That’s the one thing I find useful. And the weather for your next cities along your route is a nice touch.
Speed limit is based off the GPS. I don't have OnStar but have built-in GPS and the speed limit works on my truck.
39 minutes ago, Lewis said:
Good to know, I just took the $30 and they added the taxes plus royalty. But my 6 months is up on 4/22/18, so I will be going for the  $30 plus streaming, because otherwise i will rarely use it otherwise.
Try for $25.
That’s what I wanted to hear! Thanks!
I called my dealership about my map in my Sierra, and they told me that the dealerships can't get map updates. That it is only available to owners through the website, so there is no way for the dealership to support a customer with a complimentary update if they wanted too. My dealership's service department said that they would do the install, because apparently the install has to be done by the dealer, for free as a courtesy for customer retention.
So basically I'm boned on this one. If I have a destination that is not in my GPS I'll just use the Apple Carplay and Maps, or Google maps, but I will not spend $140 for obsolete map updates. What is GM thinking this is, 1:smash:
You’re much better off with google or Apple maps. The GM navigation sucks balls. I did the update in 2016 and complained to GM customer service about the lack of places and street names. The road i live ons name was changed back in 2007 and the GM nav still has the OLD street name. Don’t waste your money of if you do, just send it to me. It’ll be the same as doing the update, giving it away.
Waze needs to hurry up and add it to apple car play.. . i'm jealous of you android guys that got it!.. only map i use.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
