Has anyone ever ran into this?
My passenger mirror doesn’t fold when I hit button the first time. I hit it again to unfold and then fold and it will fold.
It only occurs first time I start up truck. It’ll work no problem throughout drive cycle.
Happens to so many of them. Don’t know why it does it. Seems to me like the communication to the mirror it’s slower at times than others.
Try this.
Resetting the Power Folding
Mirrors
Reset the power folding mirrors if:
. The mirrors are accidentally
obstructed while folding.
. They are accidentally manually
folded/unfolded.
. The mirrors will not stay in the
unfolded position.
. The mirrors vibrate at normal
driving speeds.
Manually fold both mirrors if they
are out of sync. Fold and unfold the
mirrors three times using the mirror
controls to reset them to their
normal position. A popping noise
may be heard. This sound is normal
after a manual folding operation.
On 4/17/2018 at 5:57 AM, Fsoldier said:
Very good info to know...Thanks!
You are very welcome.
Is there any possible way to have the mirror auto fold every time the truck is locked? I can seem to get into the habit of holding down the lock button.
Try squirting a little silicone spray in the folding crevices from time to time.
  • 3 years later...
 Did you ever figure this out?
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 830 Guests (See full list)
