CV angles
My apologies. The search functionality on the Tapatalk got me some info but not much. Concerning CV angles I’ve read that the ribs on the boot shouldn’t rub. What exactly does this mean?
Scenario:
I had wheels and tire put on my 2500. The shop took my truck and lifted the nose as far up as they could to prevent rubbing on the front bumper. This didn’t work and now I think my CV joints are angled too steep.
So looking at the pictures the ribs look pretty close to each other. Is this the rubbing? Or do they get worse? Would a 7/8” spacer fix this?
Passenger outer boot
Passenger inner boot
Driver outer boot
Driver inner boot
I will snap a couple pictures of mine tomorrow and see what they look like.  Now you have me curious....
Thinking of cranking my stock bars up just a little and am also curious. I only want 1-1.5 lift though
You’ll be fine. It’s The 3+” that you’re in a pinch
Good to know, thank you. Any rough idea on how many turns on the stock setup 1.5" would be?
I turned my bars up 3 turns. went to the dealer for an alignment,  they asked if i had a leveling kit installed?  They could not get it back into specs.  I told them what i did, they turned it back down 3 turns to get it to be within factor specs.  Im not so happy.
Makes me wonder what they are referring too. (I.e. toe, camber, caster). Camber is relatively worthless aslobg as your toe is zero’d out. The camber isn’t really adjustable either. I think they are running you through the ringer.
they were unable to get the camber adj.  toe was adjustable and is a wear item.  Camber is a wear item, and caster doesn't cause tire wear, but you can feel how this makes a difference.  How it goes over bumps at slow speed, and how steering wheel is self centering.  When i took the truck away the steering wheel was off to the right anyways!
I was told by someone, but I haven't been able to test the theory, that adding positive caster is good on these trucks when they are leveled.
Usually positive camber causes instability. I’m not sure how this would be good.
Camber only causes excessive wear if you have negative toe in.
Sorry, screwed that up the first time.  I changed it now to caster which is what I originally meant to write.
I cranked mine so that the front end was about 1 1/2 inches higher than stock. Took it to tire shop to be aligned. It had bad bump steer after that. So I took it to the dealer and they aligned it again. It has been great ever since with zero tire wear other than mileage wear. They never had trouble with it.......
But the alignment is important to the way it handles.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
