Muffler/Exhaust Options
Western96
I have a 2017 LT with the 5.3 and I don't like how quiet the truck is stock.  Even with my foot on the floor it doesn't really sound like much.  My old truck had some sort of Borla system on it, not sure which one, which sounded amazing.
I am currently thinking about mufflers like the Flowmaster 44, Borla S-type and similar.
Personally I would rather not blow $900 on an exhaust system if I can get a similar sound with just a muffler.  I know that there are some minor performance differences but I'm not trying to win any races, I really just care about the sound. From watching videos I am struggling to tell if there is a major sound difference between a full cat-back system and just swapping out the muffler.  I've seen some where it appears to make a huge difference and others where it seems pretty minor.
The options I'm thinking of are:
  1. Buy a single in, single out muffler, cut out the stock one and weld in the new one.  I'd leave the resonator on and install an AFM module to disable that.
  2. Buy a single in, dual out muffler, cut off the stock muffler.  Get a shop to weld in new tubing.  Would take resonator off and install the AFM module.
  3. Buy a full exhaust system.
Are there major differences in sound between these options?  Also does anyone have a ballpark estimate on how much option 2 would cost?  I don't think I will drop the money for a full exhaust system, but I also don't want to waste $200 on installing a muffler that won't make my truck sound much different from stock.
Thanks!
I'm not sure how you're going to do the single in dual out muffler if you only have 1 resonator. Don't see how that'll work. Me personally can't justify the price of a full cat back so bought a Carven R muffler removed stock muffler, flapper, and resonator and I'm happy.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Yeah I meant to say the opposite ... that's why I mentioned it in #1.  I don't think so clearly this late at night.
I have the carven tr muffler right now. And I cant stand it.  I bought a magnaflow 13743 which is now sitting in the garage     I'm having a black widow 250 installed tomorrow hopefully
What don't you like about it?  Also if you've heard both the Black Widow and the Flowmaster what are the differences?  To me it seems like the Flowmaster has more of a truck-like low rumble while the Black Widow has more of a muscle car sound.  Also all the clips I've heard of Black Widows sound crazy loud.  I want to be able to make some noise, but not be that guy waking up the whole street.
I have a Black Widow 250 with the 3rd cat and resonator delete. I think if you left the 3rd cat on the truck and the resonator you would be happy. If you want to ditch the factory resonator go with the Venom 300.
This is a cold idle video of mine.
Warm start with revs. Keep in mind is has the 3rd cat delete.
The carven to me just sounds sloppy
Man this is badass.  I think I know which route I'm gonna go, we'll see what costs look like but this is dope.
I must picked up a black widow 250 for my 16 Rc    I need to get it installed. I already have resonator delete but I'm keeping my cats. It will be to loud with 3rd cat removed
I recently put a Dynomax Cat-Back on my 14. I’ve been very happy with it so far. $75 rebate puts it under $250 for a whole 3” cat back. If you didn’t like the muffler it would be very easy to swap it because it uses nice stainless band clamps.
My truck is a bit of a pain in the neck for me to get to this week, would you mind telling me if the muffler was center in/center out?
I'm thinking of doing the Black Widow 250 or 300 with a single in/dual out setup, but it only has center inlet, so I was wondering if that's gonna be an issue.
I have a center/center muffler and the shop that installed it didn't seem to have an issue it being that way.
21 hours ago, Crobinson16 said:
Has anyone tried or heard the new SLP cat back system, it decently priced. Just curious about cab drone.
I have the SLP on my truck. It sounds decent, but I thought it droned a bit too much. I purchased a 3" Vibrant resonator for $85, on Amazon and cut it into the pipe when it comes back down over the axle, same as stock. Fixed about 90% of the drone.
Just so you know, the SLP comes with 2 inlet pipes, so you cut it to fit your particular truck. It's an easy install, I did it in the garage on jack stands. It comes with nice band clamps, and seals well. The Vibrant resonator is about an 1" too long for the stock location, so I cut 1/2" off each side and made my cut into the SLP over axle pipe. It slips on the outside of the SLP pipe, and I cut 2 slits into to the inlet and outlet of the resonator. I used U-bolt style clamps, and it worked well. It sealed pretty good and didn't have any leaks or movement, but I went back a few months later, when I got some flux core SS wire for my welder and welded it up permanent. You could get away with not welding if you wanted.
I hope that makes sense for you.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
