  • Replies 3.3k
Top Posters In This Topic
43 minutes ago, customboss said:
I tended bar for awhile in my 20's. They served Blind Robins, pickled eggs and warm beer. Nothing like giggly farting old drunks. I wasn't there long. LOL
  • Haha 1
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
