20 hours ago, MaverickZ71 said:
Despite customboss' best (lame) efforts, the reports of my demise have been greatly exaggerated.
Hide the women, children, and small furry animals!
Hey dude I am just a inmate here too. No power or requests of any kind made or listened to. NO joke !
  • Replies 3.3k
Top Posters In This Topic
A brunette called her car customer service saying she could only drive her car during the day.
During the night, the car wouldn't move at all.
A mobile mechanic came out to inspect the vehicle but couldn't find anything wrong with it.
Eventually he asked her if there was anything different she does when trying to drive at night.
She said, "Of course, I'm not stupid. I'm using D during the day and the N during the night!"
He said, "You are not really a brunette are you?
She said, "No, I dyed my hair."
Edited by MaverickZ71
Did you hear about the newlywed husband that was killed by a grizzly bear on his honeymoon?
He didn't suffer long--they were only married for nine days.
1 hour ago, MaverickZ71 said:
Unfortunately this is funny. Wished it wasn't. I'm glad we are able to laugh about it though
3 hours ago, MaverickZ71 said:
Only the old timers will see what's wrong with this ad.
Oh crap! I’m an old timer and I didn’t realize it until now. Lol
  • Haha 2
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
