Leveling front and tire size
Guys I just purchased a 2016 Chevy 2500 HD 6.6. I am thinking about 1.5 to 2.0" level on the front. Can I get this with the stock keys and how many turns would I need approximately? Also what is the largest tire (18")  with the stock height and  largest tire with a 1.5 to 2.0" level? thanks in advance guys.
I used the OEM equipment to raise the front ~3".  It took 10 minutes to do.  I like a level vehicle vs. the front end slant down as delivered.  The ride is stiffer but I don't travel far with it.  I have 18" wheels.  Can't speak your "largest" questions.  It's a 2016 2500HD Silverado.  I also had the TPM's reprogrammed to 50PSI all around.  All the best.
I replied to one of your other posts about the number of cranks. For tire sizes, you can fit 295/70/18 or 285/75/18 easily with 2" of lift. Those will probably clear at stock height, but will be very close. With a 2" lift, you should also be able to run 305/70/18 or 35x12.50x18, as long as you stick with stock rims.
Big whisky will the 305's fit with the GM stock mudflaps on stock rims?
Make sure if you crank the torsion bars you look at the clearance under the UCA'S to the frame. I replaced my stock UCA'S with Cognito and the ride is amazing .
Sent from my SM-P900 using Tapatalk
Thanks for the information
Hard to say for sure. I think It'll be close. A member of this forum, named "rocnrol" has ran both 35x12.50 and 305/70 on his stock rims. Might want to check out his profile & posts.
