My 2014 Chevy Silverado had 58K miles on it when I had the same issue. They replaced 2 injectors the first time and a week later another one went bad. They eventually replaced all of the injectors and luckily I purchased an extended warranty from USAA when I purchased the truck new in 2014. So far the extended warranty has paid out over $2600 total for the repairs and rental car. I had a rental for 2 weeks the second time because they didn't have any injectors in stock??????
The truck is running great now but I am afraid this problem will show up again down the road. I will probably trade the truck on a new Dodge RAM later this year. My wife's 2013 Hyundai Sonata with over 60K miles has direct injection and has never had an issue with fuel injectors.
But Gm says they don’t have injector issues...... blame it on the gas you use. Lol
$2,600 to have your fuel injectors replaced?
The labor is about ...... 30 minutes total?
Parts: $35 total for all 8 injectors, with free shipping.
https://www.ebay.com/itm/12613412-8pcs-Fuel-Injector-For-Chevolet-Express-Silverado-Suburban-2010-2018/112935653503?fits=Year%3A2014|Make%3AChevrolet|Model%3ASilverado+2500&epid=18010376600&hash=item1a4b7d507f%3Ag%3AvAoAAOSwPapbE6CX&_sop=15&_sacat=0&_nkw=2014+Chevy+Silverado+fuel+injectors+8&LH_ItemCondition=3&_from=R40&rt=nc&LH_TitleDesc=0
Edited by starman8tdc
Book calls for 4.6 hours to replace 2.
Gm ac delco from rock auto it like 78ish bucks each.
On 7/11/2018 at 6:17 PM, starman8tdc said:
  If there is carbon deposits on your pistons that is smashing the spark plugs, I would either use SeaFoam to steam clean the pistons, or stick something in the spark plug hole to scrape the piston clean, or get a comparable plug that has slightly shorter thread depth. After that, get yourself a catch-can to prevent this from happening again. I just replaced a newer Chevy truck motor, and I was amazed how much oil was in the intake plenum and intake ports in the head. That all turns into carbon the the pistons and head.
https://www.ebay.com/itm/Chrome-Square-Oil-Catch-Can-Reservoir-Tank-Mitsubishi-Eclipse-Lancer-Evo-Dsm/370907880575?hash=item565bd51c7f:g:hvsAAOSwVtZaFcBk:sc:USPSPriorityMailPaddedFlatRateEnvelope!98292!US!-1
They are soaking/ cleaning carbon off (no charge to me because I have authorized anything to be done!!) say that the 2 injectors was bad ( I wander if someone just messed up a gasket or seal and just say bad injector idk)
What does this catch can do? Or do you have a link that is informative? On my phone app is kinda hard to sift thru stuff
Edited by txab
  Hi,
      Well - basically a catch can reduces the amount of oil that enters your cylinders. An OEM engine sucks the oil fumes from the crank case into the intake (usually via the PCV valve), and burns those fumes in the combustion process. The oil fumes stick to everything, and forms carbon deposits on the piston and head. That carbon can cause pinging (detonation), spark plug damage, piston slap,  and so on.
      The catch can is a "filter" to remove the oil from the crank case vent fumes, before those fumes enter the intake plenum.
      The catch can needs to be emptied every so often, which is easy to do.
      Here are some pics and a link:
https://www.ebay.com/itm/Chrome-Square-Oil-Catch-Can-Reservoir-Tank-Mitsubishi-Eclipse-Lancer-Evo-Dsm/370907880575?hash=item565bd51c7f%3Ag%3A-pkAAOSw2FVbRpFR%3Asc%3AUSPSPriorityFlatRateEnvelope!98292!US!-1&_sacat=0&_nkw=chrome+catch+can&_from=R40&rt=nc&_trksid=p2380057.m570.l1313.TR11.TRC2.A0.H0.Xchrome+catch+can.TRS1.TSS0
    4.6 hours? WOW! I have never seen any injectors that were not easily accessible. Learn something every day. Any chance you could upload some pics or repair instructions?
    As for the more expensive injectors, I would not go that route - but that's just me. I have had good luck with the cheap injectors on many rigs.
It sounds like you're talking about replacing injectors on a typical port injected engine.  This engine is direct injected.  Much different deal.
These injectors sit under the intake
    The new design doesn't look difficult to work on, but it would be a little more time consuming to repair. Pulling those injectors looks like it would be about the same as replacing the knock sensors on a 5.3L (generation 3).
    Looks like some of the direct injection engines have specially designed pistons as well.
    From what i'm seeing, some vehicles have both direct and port injectors on the same cylinders.
    I look forward to working on one, it would be an interesting engine to take apart.
    Check out the pics:
15 hours ago, starman8tdc said:
That was the total price for 2 visits to the dealership and 2 rental cars. The first visit was 2 injectors and the second was 6. I have to wait 2 weeks to get the parts for the second visit. I agree, it shouldn't cost that much but those are dealership prices. I am just glad I didn't have to pay out of pocket for it.
Do you know if your engine has direct injection or port injection? If its direct injection, then the install time would be a bit longer, but still - the bill is extremely high. Your right, the dealership charges a lot. I'm glad to hear that you didn't have to pay for it.
$1,800 is the going price by the time you get 8 injectors, all the extra seals and gaskets required and the labor to really it all apart.
Sent from my Moto G (5) Plus using Tapatalk
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
