58 minutes ago, starman8tdc said:
Do you know if your engine has direct injection or port injection? If its direct injection, then the install time would be a bit longer, but still - the bill is extremely high. Your right, the dealership charges a lot. I'm glad to hear that you didn't have to pay for it.
It is direct injection
57 minutes ago, cpttimerestraint said:
$1,800 is the going price by the time you get 8 injectors, all the extra seals and gaskets required and the labor to really it all apart.
Sent from my Moto G (5) Plus using Tapatalk
But you have r&r injectors twice. Plus diag twice.
So we picked up the car on Friday.
I was told that the fuel injectors they installed was bad out of the box. All the talk about carbon on cylinders and blah blah blah was just that imo.
They “said” they replaced the 2 injectors they just replaced..... I find that hard to believe but.... we drove the car home and the light didn’t come on or spit or sputter at this point.
On 7/10/2018 at 2:24 PM, YJSONLY said:
Sooo I stopped by today because I had to get something out of the car. No call just showed up.
Talked to the mechanic myself.... said they have test for leak down test and it all checked out.
Says that it is having a miss but not sending a code for a miss. Only a fuel trim code showing.
Had to dig around. Found that the number 7 plug was gapped/smashed due to carbon build up on top of the cylinder. Said he put new plug in. Ran vehicle and they same code. When pulled new plug was back to close gapping. Said that need top of cylinders needed cleaned of carbon.
Sorry dude but the spark plug gap doesn't get "smashed" from carbon build up. If spark plug gap is truly "smashed" you have a mechanical failure of some sort. I am not buying that explanation.
Like I said I think they screwed up something when installing new injectors. Ie bad seal, o ring or gasket....
So I really drove it myself today vs my wife. And at idle in park the rpm gauge is not consistent. Varies about a solid needle width. This normal?
I would pull the plug on that particular dealer. I think a fresh set of eyes on the problem is warranted at this point. Maybe another Chevy dealer tech has seen this problem before?
And more money out of my pocket to boot tooo. Might come down to that tho. This isn’t a small dealer either.
Sometimes the smaller dealers are way better.
Ha. The other small dealer I took it to. Didn’t even have a tech.... yes a Chevy dealer that had zero techs.
On 7/12/2018 at 10:59 PM, starman8tdc said:
    4.6 hours? WOW! I have never seen any injectors that were not easily accessible. Learn something every day. Any chance you could upload some pics or repair instructions?
    As for the more expensive injectors, I would not go that route - but that's just me. I have had good luck with the cheap injectors on many rigs.
If you haven't done a direct injection repair yet I suggest you watch some videos on it or take a small class. The pressures of the systems are very high, it's important to bleed off the system before you start working on it (pressures can reach 2,000 psi during operation). The high pressure fuel pump is very expensive, so be careful not to damage it when you remove it. And the injectors are high voltage (if I remember correctly) and they are probably a pain to remove because they are in the cylinder and head...I'm trying to imagine how bad it'd be to remove with over 100,000 miles on them. Yikes.
Very few systems use BOTH the direct and port injection together, although that may change with all the carbon issues on the valves, but that is expensive for manufacturers (and they care more about profit than reliability).
Honestly I haven't heard about many problems with the actual systems themselves, more with the carbon buildup on valves than anything else. I used to own a direct injected Lexus...178,000 miles and not one single issue. In fact I've seen cars with 300,000 without issue.
pretty surprised to hear the GM injectors failing at low mileage....even more surprised it's  not covered under warranty. These systems aren't exactly "new" anymore, every car on the road uses them now.
   Good info, thanks for posting.
   From what I have read, the direct injections systems are definitely superior to all the predecessors. I have been working on various cars for decades, but I have not had any issues come up with that particular fuel system.
   I will definitely study the system well before taking one apart.
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
