8 speed issue
So for the past couple of months my 8 speed has had fluctuating rmps when driving at a constant speed and shuddered somewhat. Yesterday on my way home from work it got really bad and now has the vibration that shakes the steering wheel. I know it’s part of the torque converter problem and it’s going Monday to be looked at. They said they will flush it change the filter and use a synthetic fluid this time. I know a few people have had this done and was wondering if it actually fixed it or not.
Mine started doing the exact same thing. I have an appointment in 2 days to take it in.
One other thing I have noticed, is the trans temp reading is erratic. By that I mean it will read 25 deg below ambient when starting out. It will jump 40 to 50 degrees in a second or 2. It fulctuates wildly and does not correlate to reality. It may be related
Sent from my SM-T817V using Tapatalk
It also seems to not know when to shift and up shifting from 2nd to 3rd will feel like it’s making the truck bounce. Let me know if it works when you get it back. Did they give you a time frame on how long it would take?
From what I have read on here and on the Camaro forum, doing a full transmission fluid exchange takes care of the problem most of the time.
Ugh, you guys are scaring me.  I started having the transmission surge at vehicle start up yesterday, but someone posted the TSB that it is normal and no repair required, and today I did like someone suggested and let it idle for about 30 seconds in park before shutting it down.  It never surged at start up once, so the idling thing appears to work.
I do have the thunk when coming to a stop as it downshifts from 2nd to 1st.  Today a couple times it thunked hard after coasting then getting back on then throttle at low speed (like coming to a stop light, but not completely stopping and adding a little throttle to move up another 10 feet).   It felt like when you have a really bad u-joint, or like there's a lot of slack or lash in the gear mesh.  Press the pedal and it spins up to take up the slack and then thunk when everything engages.  It only did it a couple times, but that's something else to keep my eye on.
God, I hope this thing doesn't turn out to be a headache.  I haven't had a Chevy vehicle since 2001 and I so love everything else about the truck, please, please, please don't become the reason for me to leave Chevy again....amen. :-)
How many miles are on your truck?  If it was me, I would do a fluid exchange. If it is under warranty, take it in and have it done.
On 7/3/2018 at 3:06 PM, EDL said:
I just rolled over 700 miles on it today.
700?  Flush it Son!  Demand it and pay for the fluid......When you get it back lay into the pedal some it will take a few thousand miles to stop thunking in the 1-3 down shifts but it will disappear....weird but true!  I am sure mine would have gone away sooner if I hit the pedal harder but too late now..
I've had some issues with my new 2018 Sierra Max tow with the 6.2.  Same things as above..surges when starting, thunks when coming to a stop and the shifting is hard sometimes.  I have just over 700 miles on mine as well.
So I should take it into the dealer?
So my issue was resolved. The dealer verified it was TCC slip. They performed a trans fluid drain and flush 3 times per bulletin. Then performed a service fast learn. The shudder and rpm jump are gone.
The erratic trans fluid temp reading is a faulty sensor. It is in a harness and they had to order it. It will take up to 2 weeks.
Only took a full day
Good deal. I’m leaving town next week and didn’t really want my truck setting at the dealership until I got back
My 2017 Sierra had the thunk on downshifts/creeping down the freeway.  13 months later and 32k miles it has gotten significantly better. Software update did nothing,  and I never got it flushed. So GM has no fix for this "#worksasdesigned" but they have collaborated with the Blue Oval to create the 10 speed auto. I recently drove a rented F150 with the 10 speed auto and initial impression are ok. This is the same 10 speed that will be in 2019 GM trucks according to reports.
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 478 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
