Oil pressure 6.2
I know this thread has beaten like a dead horse. But from what I seen in common is that most people have around 20psi or higher at hot idle. I've noticed this summer(can't remember last summer) that my oil pressure is below 20psi.i would say between 15 to 17psi. This is after driving for maybe 25 mins mix highway city. No additional weight in the truck. I've seen the pressure slightly lower than that but not much. Cruising is usually around 30 to 35.i run mobile 1 0w20 with mobile filter and change oil around 5000 miles. Currently around 3200 on oil. Just wondering if you think it's a indication of weak oil pump or something.  My 2016 5.3 never went that low
  • Replies 49
Here's a real hot idle after pulling a trailer up a monster grade at 70 plus.  Less than 10psi.  At normal operating temps I regularly see 12ish.   Outside temp 110.  I came on here for trans cooler suggestions and saw your post.  Motor only has a few thousand miles on it and so this was my first towing trip.
What is your oil temp when this happens?
I seem to remember the old saying, 10 psi for every 1000 rpm.   If that’s still true, then you are close but fine.   Then again.  It was an OLD saying....?
I'm guessing you're indicated pressures are accurate or close.  I see in the 12 psi area at idle once the engine warms up and OAT is 80F or above.  I have run Mobil 1 in the past few trucks since new.
If you're concerned, take it to the dealer.  But, I would bet dollars to beers they'll say "it's normal".
What's your dash show when it's 10psi. Is the dash Farley accurate. I don't tow with my truck at all. Mine is just mostly highway driving. I'm not going to say I don't beat on my truck(anyone with a6.2 that says that it's lying) but it doesn't matter if I just cruise at 70 either
Please Run don’t Walk to your dealers service department, may have serious consequences the longer you wait. Good luck and let us know the outcome
When the temperature outside is cooler below 75 80 ish. It will not go below 20psi. It's only goes below 20 when it's hot out side. I blame the 0w20 water weight oil
I have not logged temp, but I'm sure its probably scalding.   Normal low for me is 12psi.   This is just the lowest I've seen and probably is from the high temps and thus the only reason I took a picture.   According to dealers 6psi is the minimum so apparently they don't care about anything above that.  The corvette boards recite roughly the same.  It should be noted that mine is a rebuilt motor as well and I'm more interested in whats normal in case I want to take it to the shop I had it built at.  Some say cam bearings could cause this as well as an oil pump.
I looked at other sites and they confirmed the use what ever oil weight that gets you 10 psi/1000 at 212 degrees reasoning.
Not sure about that cause my 6.2 oil pressure gauge always stays above 20.
Please do next time you tow as that is contributing to your issue.  Judging by the coolant and trans temp and description of use, I would guess your engine oil exceeded 260 degrees.  Do that with thin oil and you get really, really thin oil....
How much above 20?I would love for mine to be above 20.my we 2016 5.3 stayed above 20. But not by much.
I am a little concerned about it. But I hear no engine noise at all. I know dealer will say Normal
Being in the desert and towing up big grades I was half expecting temperature problems so I put a 30 or 40 weight in it before I left.
Not sure why some choose to keep a razor thin margin for error in these not inexpensive machines. The 0w-20 spec was made to save .1 mpg for federal mandate and not to tow a trailer up a hill at 70 in the heat. Put in thicker oil of your choice or risk it all its your choice. Do a Used Oil Analysis on this fill and see if there are some bearing metals in the oil. As the bearings wear the pressure will get even lower accelerating the wear. Good luck
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
