I wanted to make sure of my facts before I weighed in so we went for a 150 mile jaunt. Not a particularly hot day, Mid 70's. Dead cold high idle pressure 28 psi on a scan gauge. Fully warmed up with oil temp over 205 F 24 psi =/- 2. Hot idle 560 rpm 20-22 psi. Hot higher speed (2000 rpm) 28 psi. Over 3,000 rpm variable from 30 to 52 nearly linear with rpm. Same numbers I have logged for 100 F days.
On the dash gauge we get a different story. Cold idle 42, Hot down the road 38. Hot idle 32 and nailed to the wall 80+. Point is the dash gauge and actuals are not even close. The dash gauge is a 'feel good' idiot meter.
Yes my motor is the 4.3 not the 6.2 BUT they share the same oil system strategy. The call out of this little motor is 5W30 and I run 0W20. I've tired 10W40 and it makes zero difference to the oil pressures when warmed up. A bit higher when cold. Because??? Unlike your grandfathers small block which dumped excess oil pressure to the pan after the pump but before the oil galley these critters dump the excess at the end of the circuit and use a variable displacement pump system.
On ‎8‎/‎16‎/‎2018 at 5:36 PM, ltzsilverado said:
 I just looked the information up on all data and min. Oil pressure is 22psig at 1000 rpm , 30 psig at 2000
check and check. The numbers it should read with a Tech II or equivalent OBDII tool.
Almost every one of these I've seen will hold the dash gauge roughly 40 psi in cruise and over 35 dash idle. You gauge would give me pause and it could be literally anything. Sending unit, Screen, Gauge and/or worse. Have it checked out before the warranty expires. Devils in the details. Have a nice day.
That's where Clyde lives. When I stomp on it stage 2 kicks in and I damn near hit 80, but otherwise he hangs out between 35 and 40.
It would be a good idea to check it out. You've got nothing to lose man.
  • 1 year later...
He everyone. I have a 2015 GMC Denali with 6.2. and for my first 30 days, I love it! but, At 110 k I just lost the engine, I purchased it at 108K. Was cruising down highway at around 65 when all of a sudden the engine wanted to die, would not tach up, even when trying to give it gas is continued to decelerate, I thought for sure it was the fuel pump. I watched the oil pressure drop to almost nothing when I pulled over on side of road. It would not start even though it would crank. Mechanic said engine is toasted. I just purchased 30 days ago from small car dealer. It will start but the motor knocks, squeaks and will not idle of course. The only info I have about the history is it was extremely well maintained, oil changes every 5-6 k. It had a code in the computer history saying it had a problem with "crankshaft sensor" recently. Dealer had know idea what this was and said to me don't worry, I will stand by engine if something happens. It did have the occasional acceleration smoothness problem that we all experience with the V4/8 fuel system, I understood that the hesitation does have something to do with the crank sensor issue". I also heard that it had one broken valve spring that was replaced a month before I purchased. Can someone please help with what you think happened here? I'm absolutely demanding a new GM crate engine to be put in, love the vehicle. need advise on what to do here.  Bob from Ma.
make a new thread
not enough info either, did the oil end up on the ground?
I’d ask the mechanic what is wrong with the motor, he must know if he said it needs to be replaced
This is my 3rd K2, have never had an issue with transition of the DOD.
Kind of sounds like it had a major failure, and was not fixed properly.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
