CEL came on after getting CAI
Myersdj
So I drive a 2018 Chevy Silverado crew cab 5.3L V8 and I just had a S&B CAI installed. A few engine cycles later my CEL came on.  The code is p0102 (MAF Sensor). I’ve tried a few different things that makes the CEL go away but it keeps coming back. Any advice on what to do is appreciated!
Go to a place like Autozone or O’Reilly’s and see if they won’t reset it if you don’t have a reader. When you unhooked it to install the new CAI, it triggers a code.
Is it a wet filter?  If so may have had too much oil and it got on the MAF sensor.
check to make sure both breather hoses are tight at the intake tube and the engine ends.  And all other connections are tight and installed properly.  and make sure the MAF is plugged in all the way
Might also try cleaning th sensor with spray.
Did the sensor get bumped or maybe touched on disassembly or reassembly?
I thought I remember the battery needing to be disconnected when disconnecting the MAF sensor?
I’ve disconnected/reconnected the negative side of the battery a few times now....it works, but only for about 30 minutes
Everything looks good to me
Must be something else triggering it then.
1 - take it back to where you had it installed and let them deal with it, or
2 - disconnect the neg cable for 30 mins.  Unplug MAF sensor plug and reseat it.  Connect battery and it should be good to go.  Like mentioned earlier, if you unplug the sensor with the battery connected, it'll throw a code.  Nothing really to worry about though.
I have unplugged my MAF sensor connector to replace the passenger headlight bulb without disconnecting battery cable.
It was probably disconnected for 20 min or so, and I never had the CEL come on after hooking everything back up.
Make absolutely sure the MAF plug is seated completely, too.  I unplugged mine once when taking out the airbox to swap headlights and didn't get it plugged back in all the way.  Drove me nuts for a couple days trying to figure out what was wrong.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
