Control arms hit after suspension mods please help
Just now, 14cris said:
I dont get how the trucks are a 1:2 ratio if it didnt raise it 5” though
All i really wanted was a damn 3”-3.5” leveling kit and call it a damn day
Be ause your droop stops wouldnt let it. 3-3.5 is atill to much for a 4x4. Your cv angles start getting out of wack at about 2.5ish
  • Replies 94
Even with a diff drop?
Since you have a diff drop. Pull your spacers out and buy a moto fab 3" level spacer. Ot ahould be about 1.5" tall. You should be perfect with that.  Upper balljoint angle might be a little out of wack but you can add un upper control arm
What about the rough country spindles? They were 300
Live and learn. Cut your losses
What im asking is do i take it off? Or leave it on
Id pull it pff and replace it with a upper control arm
So put my stock one back on, and buy lift control arms? Like the rough country ones?
Man i do appreciate you clearing this up and taking your time explaining this
I wouldn't use rough country.  Im not a fan of cognito but cognito or reklez upper arms would be best
Gotcha, they both require cutting the droop stop right?
I have basically all of this
I have the same strut spacers
Same knuckles
Same diff drop
