Control arms hit after suspension mods please help
You have 6.5" of lift on this setup!? If you really do there's your issue, thats entirely too much lift for those methods.
Sent from my SAMSUNG-SM-G890A using Tapatalk
No, so all in all; i have about 4.25” of lift
1” shock spacer
2.5” strut spacer
And 3” lift spindles but they didnt do anything but lift an inch and it gave my upper control arms better angle i have to admit
  • Replies 94
1” shock spacer
2.5” strut spacer
Take out the 2.5” spacer then and see how it is. That would be the best combo of what you have
I took off the 1” spacer from the bottom, now my control arm doesnt hit the droop stop
But slightly rubs the coil, is this bad?
21 hours ago, 14cris said:
I have a 2014 sierra slt, 4wd
originally from the dealer it’s had a 1” RCX spacer under the shock
i installed a 2.5” spacer on top of the strut and the diff drop kit and my arms hit the droop stop
the tech at the alignment shop told me to order the lift knuckles “spindles” from RCX to
make the arms clear
well they didnt clear and are hitting the droop
stop and strut coil now!!
Im at a loss what can i do???
to begin with from tire to fender i has 7.5” of height
after top spacer i had 10.5” of height
now after spindle install i have 11.25”
i dont want to get higher and higher i just want my arms not to hit anymore
Does it hit when turning?
im just curious?
Plus. Putting spacer bottom of shock, and on top of the strut?
thats never recommended.
im just curious?
Its hitting just standing still
I havent done both sides because i ran into all the problems with one side
Yes thats bad and take a picture of your angles
a2419f1723704b777b58ec6206646364.jpg41d3cb3e56b7d9da251f6e964947f2ff.jpg0e234adb3aa9e9fee451795485b7f545.jpg
Excuse the tape, i was using it to hold some stuff out the way
I'm gonna say your knuckles are the problem (among other things possibly).  What brand is that?  They look like shit.
Rough country
How am i supposed to see the angles like that?
Put the tire on drop it off the jack and take picture from back and front , something is off , let it down with the tire  turned to left  full lock , I think its not that bad and get a pic of diff drop tough to see it  But you are maxed  , Definitely lose the 1" spacer
I did take off the 1” spacer
It helped clear the droop stop, now it’s just hitting the coil a little bit 91708aeec8c6ba4f790bb9845c16ad66.jpg
