Audio install
Budtn15
Guys I need some help I’m putting a sub in my 15 crew cab. I’m wanting to install one 12” sub under the rear seat. The problem I’m having is finding a box and sub that match each other. If anyone has any single 12 setups I could see that would be awesome also where the box came from and what the sub is.
http://probox.com/products/car-truck-enclosures/chevrolet-gmc/crew-cab/cc14-112a-1600
This link has a powered 12 in a box specifically made for the sub. Read several good reviews.
I’m also in search of a sub setup just not sure which way I’m gonna go with it. So far from my findings, prefabbed boxes a lot of times will not work as well as a custom box. Maybe check some local audio shops see how much one would cost.
I've been considering one of the enclosures from SubThump, here is a single sub enclosure:
http://subthump.com/Chevrolet-GMC-Custom-Subwoofer-Boxes/Silverado-And-Sierra-Crew-Cab-Custom-Subwoofer-Enclosures-by-Subthump/2014-Up-GM-Crew-Cab-Single-Downfire-Box.html
I'm not sure of the quality, but the pictures look good. I have a center console and don't have the Bose system, so I think I am going to add a subwoofer to the center console first and see how that does then add subwoofers to the rear if that doesn't do enough for me.
I had a double 12" box with two Kenwood Excelons in it in my 2011. I've had a hard time getting on board with Kenwood though. This time on my 2015 I kept everything stock and just added a 500 watt / 300 rms amp and took a double 10" box I already had and cut it in half. Sealed the end and used a 10" JL 10TW1. I thought about a 12 but personality I like a tighter bass. The JL gets pretty low too. Hits super hard in my opinion and it's clean. I have a bass knob under the dash so I can fine tune it to the song and style of music.
Just thought I'd throw the single 10" possibility out there.
I’ve looked at that 10 also just wondering if it would give me a decent low end bass, I’m not looking to rattle everything loose just want to be able to have a good bass as well, I listen to everything from rock to rap to country I’ve had 12s in everything and a kicker 10 in the last truck I had which was an f150 but it couldn’t really hit the lows like I wanted maybe the jl slim can hit lower
I had the same school of thought. I had these Kenwood 12"s and a couple single boxes that would only fit standing up. I just couldn't get the sound I wanted. I could shake the truck hard but not what I wanted.
Decided to spend the money on the JL sand I couldn't be happier. I may even get one more and a double box that actually fits. The one i modiy was for a 2011 crew cab, I gave a double cab. Good luck!  Oh and the reviews for the JL says it can hit lower than most tens is correct.
Is yours the thin series 10
The model is JL10TW1. I'm not sure but there may be one that's just as thin or maybe thinner. Not sure. I went for one that was a little more expensive but the guy running the store said with my amp this one would be better suited to me. It is a thin sub, no doubt about that.
JL Audio 13TW5 is what I would go with. Had one in a 2009 Escalade I had then transferred it to a behind the seat custom box in an F250 I had. I’m looking at another one for my 17 Silverado. No problems fitting under the seat in a low profile box. Paired with an MX500/1 amp and the thing will rock.
I’d love the 13.5 just hard to justify doubling the price of the system on just the sub
Well I’m gonna go with the jl 10tw5 and a 500 watt amp next question is how do you all have your bass knob mounted
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
