Automatic OBD-II Monitor With 5.3L V8
I've had an Automatic plugged into the OBD-II port of my 2010 commuter sedan since buying it new.  And it's been great for checking the occasional CEL code.  I was able to immediately find out when the code thrown related to my catalytic converter, which on that car had a history of throwing metal into the engine since it was located so close to the block.  So I was able to immediately get it over to the shop before it had a chance to torpedo my engine.  Another code which comes up every few weeks during the spring and fall (when temps fluctuate wildly here) is a nuisance code that just needs to be cleared.  And again Automatic and it's app have been great.
I'm thinking of getting a new Automatic (https://automatic.com) for my 2018 Silverado LT with the 5.3L engine.  Anybody have any experience with this combination or know of any problems?
Having anything plugged into the OBD-II port keeps On-Star from being able to generate the monthly reports they send for you.
That was the only downside I saw when running my Automatic adapter in my 2014
I just have one of those $100 Innova OBDII readers I carry on long trips. Lately I keep it in the 2014 because it has a reoccurring trans issue that GM can not solve. Are these "automatics" vehicle specific or a plug and play in any OBDII port? If they are VIN or vehicle coded, you may just want a handheld that you can keep in the glove box so you can use it on your wife's or friend's car too. If the "automatics" are plug and play in any OBDII that's a great idea because my handheld doesn't give me much for information besides the code so I always just end up Googling the code once I have it and go from there.
I got a cheapo one off Amazon for like $20. Like this ->https://www.amazon.com/Foseal-Scanner-Adapter-Diagnostic-Android/dp/B00W0SDLRY/ref=sr_1_6?ie=UTF8&qid=1538500606&sr=8-6&keywords=obdii+reader
I do not leave it plugged in when not in use. I have used it on my other car to check and clear codes. My truck has not thrown a code yet, but I did use it when moving my plow in hot weather to monitor the transmission temp. It worked well. Other than that i have only played with it a little here and there.
I think the code reader is pretty simple in design, anything that sends the signal to your smartphone is very handy. I have no prior experience with "Automatic". I use the torque lite app for mine.
It's not VIN or vehicle specific.  You just have to check on their site to make sure the adapter works for your vehicle.  But it either does or it doesn't.  There's just one.
And it is supposed to monitor for signs from the computer that there has been a crash.  And you can program it for who it contacts - since it links to your smart phone.  My existing one makes a little beep when I start out if it's able to connect to my iPhone or a different signal if something with the connection went wrong.  How well it works in the event of a crash is questionable - I've read people report airbags deploying and it didn't notice.  But theoretically it's "On Star-lite" permanently for what On Star would charge for just a few months of their safety service.
So although it does have the ability to read codes and clear them, it's meant to be more than just an OBD-II code reader.  They are really shooting to be an "On Star-lite" type service - including for those makes/models for which On Star isn't even an option.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • $4.26 85 oct
