2015 brake job
Has anyone changed the brakes on their 2015+ 3/4-1 tons yet? mine have started to fade fairly quickly.... im at about 48k miles, and it seems a little early for a brake job. I will say though, I did take 2 2000 mile trips with a fully loaded 24ft trailer and a non working trailer brake. Non the less, i honestly can NOT get this caliper off. Air, battery, heat, pipe on a ratchet, I've tried EVERYTHING and I CANNOT get this caliper off. Anyone had any issues with it as well? The guide pins are sealed, so the bolt that I'm talking about is the actually caliper mounting bolt. Maybe one of you has some sort of tip or trick to get this done.... never ran into this issue before
here for the result as i'll be doing brakes in somewhat of the near future. 52k so far, but havent pulled a single thing. No direct sign that i'll need a change soon, but i'm sure it's coming.
  • 3 weeks later...
105k on my '14 DRW DMAX and still going strong on OEM brakes. 98% of my miles have been towing a trailer 5 days/wk, which weighs between 10-15k. Trailer is 6 years old and has needed one full set of brakes replaced 18 months ago, based on how I keep the gain adjusted.
Sent from my SM-G950U using Tapatalk
So how does this guy get the caliper off?
Seems like he knows what he's doing, so is there a trick?
We all need to know....
The rubber plugs are pried out of the calipers and the slide pin bolts are removed, The caliper is hung on a wire you rig up to make sure its not hanging by the brake hose and get it out of your way.The bolts I believe he is talking about, hold the caliper bridge to the knuckle,they are loctited from the factory and can be a real pain in the ass to remove,we use heat to soften up the thread sealer and hit it with an impact gun. Make sure you lubricate those slides and reinstall the rubber plugs.
  • 4 weeks later...
well guys, sorry for the late update, Turns out the reason for my brakes fading so fast was a caliper that was frozen, and caused it to burn through the entire pad on the backside of the front caliper. Luckily, I have an extended warranty, so I ended up just paying the deductible and the dealership changed 1 caliper and both sides for pads. The seemed to think it was a common issue with trucks up North, although I can't say that I've had the issue before, and it happened in the middle of the summer, so I'm assuming they have no idea what they're talking about. None the less, crisis averted, and the brakes are back up in good condition. thanks for all the help!
My 2008 GMC Canyon had lots of seized calipers.  One stuck so bad, I could smell burning brakes when I got off the highway.  I replaced it.  A few years later, when I went to get it safetied to sell it, they told me they had to replace both calipers, since they were both sticking.
  • 1 month later...
The dealers correct seized calipers are very common in vehicles in the Rust Belt. It happening in the summer doesn’t matter rust doesn’t stop just because there’s no snow on the ground.
I will need new brakes soon and I’m at 160k on my 2015 2500
  • 1 month later...
My brakes where about wore out because of the shitty little seals GM put on the end of the calipers. One of them was torn and the slide pin was starting to get seized up.
  • 6 months later...
that's crazy miles on stock brakes
Apparently I got lucky, I just changed my pads and rotors at 130k miles and I bet i still had 20-30% left...
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
