07-13 Front Turn Signal Bulb Replace
I was PO’ed when I had to change drivers side turn signal bulbs.  Little did I know that it was a cakewalk compared to the right side bulbs.  Removing air cleaner box and reaching through that hole to change the bulbs is a real peach.  Just disgusting.
Pull the radiator / core support cover off after removing the push pins. Then, unclip the metal clips of the grill from the grille support and slide forward the drivers side a bit (or remove completely), then you have enough room to  remove the 3, 10mm bolts holding the headlight in and can replace the bulbs that way.
Same issue when changing headlight bulbs also
